confused NB - thinks it's a duck!
pastapete
Postby pastapete » Mon Jun 26, 2006 9:56 pm
well, it waddles its bum at times...
let me explain, at 30kph or so there is a disconcerting feeling, you'd swear one of the rear wheels was out of round, the arse of the car feels like it's waddling, for want of a better description.
Jacked the car up, they spin as true as an honest roulette. last service records 1,000km ago mention a complaint about front wheel wobble at low speed, remedied by balance and rotation. I'm at a total loss, the car drives great otherwise, and obviously I drove straight through that zone on my test drive last week...
wondering where to start looking?
irwin83r
Postby irwin83r » Mon Jun 26, 2006 11:02 pm
might be worth gettin a wheel alignment though it may not be the problem they may find what is wrong when they go to do it.
dose it feel like the back end is totaly free of the rest of the car or dose it just wobble..?
dose it stop once speed increase or turn into more of a vibration?
check the wheel nuts are tight too..
JBT
Postby JBT » Mon Jun 26, 2006 11:05 pm
Tyre bulged? What brand of tyre is fitted?
Fra66L
Postby Fra66L » Wed Jun 28, 2006 7:00 am
PP,
I know exactly what you mean - been there! :evil:
5s are really sensitive to wheel balance and I had my OEM NB alloys blanced (ask them not to round the wieghts but be as exact as possible) as well as moving wheels to different positions. With the wheels moved, the shimmy semed to be similar but felt a little different depending on where it was. It always felt like ther rear end was shaking in some way or another though...
Visited the local tyre place, explained the problem and sure enough, two of the rims were slightly bent (bloody potholes) but I could only see the problem, just, on one of the wheels. Could feel the flat spots when the wheels weere spun up though...Took the wheels to a wheel repairer they recommended who trued up the wheels and hey presto, no more bum wiggling.
The NB alloys are really quite light (going lighter in aftermarket rims is not easy and mostly expensive) and as a result I suspect they damage a little easir then other (heavier) wheels.
Best of luck,
T
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
AJ
Postby AJ » Wed Jun 28, 2006 7:54 am
JBT wrote:Tyre bulged? What brand of tyre is fitted?
first thing i thought of too JB...........sounds like a tyre may have popped a couple of belts..........considering that a balance & ROTATION has fixed the front wheel wobble 8)
XMX5 Rogues
pastapete
Postby pastapete » Mon Jul 03, 2006 6:48 pm
Leaving no stone (or wheel) unturned, taking a 3 pronged attack
1. precision alignment today
2. Champiro tyres (rear) and Goodyear Eagles (front) get replaced with Michelin Precedas tomorrow ($50 cashback on set of 4)
3. One rear rim has a tiny flatspot on the inside, booked to be trued on Thursday am.
hopefully all signs of wobble will then be gone :D
JBT
Postby JBT » Mon Jul 03, 2006 11:48 pm
Be interested to hear of the outcome.
Garry
Postby Garry » Tue Jul 04, 2006 9:21 am
That could be your problem right there.
pastapete
Postby pastapete » Wed Jul 05, 2006 2:17 pm
shoulda known the comments about buckled rims would be the most accurate, the tyre fitters yesterday identified 3 of the 4 rims as being buckled! Easily fixed, the rim truing place wants the wheels for 3 days, but it will finally resolve the issue
JBT
Postby JBT » Thu Jul 06, 2006 11:29 am
Do you mean buckled as in 'hub face on a different plane to the rim face' i.e wobble, or as in 'kinked rim edge due to pot hole or similar' :?:
pastapete
Postby pastapete » Thu Jul 06, 2006 7:03 pm
took 2 rims in today, both were identified as having flat spots, bloody expensive to fix at $120 per rim, for $45 more per wheel I can get new aftermarket rims! The 3rd one will go in tomorrow, and they want the rims until Wednesday. One disadvantage of living in a small provincial city is the lack of competition for work like this, only one shop in Tooowoomba does alloy rim straightening.
Bevan
Postby Bevan » Thu Jul 06, 2006 7:41 pm
$360!!! :shock:
You can get some tasty second hand rims off ebay for that.
pastapete
Postby pastapete » Sat Jul 08, 2006 8:58 am
well, to allow plenty of time for rim repair, and to give me some rims for track days, I've purchased a set of BSA AU122 rims, they look fine, with my old tyres weighed less than the original rims with new tyres
http://www.bsawheels.com.au/users/Produ ... spx?id=193
the picture's a bit deceptive, as the outer rim is actually not gold at all.
cheap as chips really, $165 per wheel, with my old rubber fitted and balanced - no wobble either, so that eliminates the bulged tyre theory...
rodent
강남 스타일
Postby rodent » Sat Jul 08, 2006 3:08 pm
pastapete wrote:well, to allow plenty of time for rim repair, and to give me some rims for track days, I've purchased a set of BSA AU122 rims, they look fine, with my old tyres weighed less than the original rims with new tyres
:shock: Where did you get those wheels from? I've been looking for something like that...
Got any pics of them on your car?
jonno.
pastapete
Postby pastapete » Sat Jul 08, 2006 6:50 pm
BSA wheels are readily available, Mania has them for $170, but freight adds to the cost. They came in at 0.7 kg lighter than the original rims, but that was with worn rubber as opposed to new, anyway, there is no weight penalty that I can see
http://pjmatt.customer.netspace.net.au/bsa.jpg
Users browsing this forum: No registered users and 129 guests
