which swaybar?
mossy
which swaybar?
Postby mossy » Thu Jun 22, 2006 7:07 pm
I have a set of jap spec tein flex on the way and was wondering which front sway to go for, the 22mm or adjustable 24mm?
RobbieRat
Postby RobbieRat » Thu Jun 22, 2006 8:35 pm
Go the adjustable in whatever size, (depending on spring rate) i have a 24 adjustable on the front and its great with Kings.The 3 positions are quite noticable in effect to each other especially with new bushes.
Being able to soften the front in the wet made a difference in laptimes at a recent hillclimb event.
Matty
Postby Matty » Fri Jun 23, 2006 3:15 pm
what spring rates?
assuming 7kg/6kg F/R, then I'd go for either a 24mm bar, with or without a rear 12mm bar, or a 22mm front and no rear bar.
Probably 24 on stiff with the OEM 12mm rear would be ideal.
Astroboysoup
Postby Astroboysoup » Fri Jun 23, 2006 4:55 pm
so no upgrade on the rear sway bars???
AustCars.net - It's like Facebook but for cars!
mossy
Postby mossy » Fri Jun 23, 2006 5:10 pm
I'm going with the 24mm adjustable whiteline bar :mrgreen:
Matty
Postby Matty » Fri Jun 23, 2006 9:43 pm
Astroboysoup wrote:so no upgrade on the rear sway bars???
with those spring rates, hell no! (unless you love oversteer and wheelspin...)
Astroboysoup
Postby Astroboysoup » Sat Jun 24, 2006 12:05 am
how about that.. never knew that....
so looks like i'll just be getting front whileline adjustables
Postby Okibi » Sat Jun 24, 2006 8:53 pm
I have the racing beat front AND rear sways on our NB8A.
So far they're great but I haven't played with them on the track yet.
kula
Postby kula » Sun Jun 25, 2006 5:48 pm
hollow racing beat one ftw
