Can any wheel be re-drilled?
Bevan
Postby Bevan » Wed Jun 21, 2006 3:11 pm
Just wondering if you can get any rim re-drilled? If I can get a cheap set of wheels in 5-stud (and there are enough out there), could they be re-drilled? If so, approx how much?
Or are there way too many variables to even consider it?
Thanks Guys,
Bevan :)
Garry
Postby Garry » Wed Jun 21, 2006 3:25 pm
I think you'd have a bit of trouble getting the space to drill 4 more holes in a 100 PCD wheel without there being some overlap with the holes that were already there.
bigdog
King of the kennel
Postby bigdog » Wed Jun 21, 2006 3:31 pm
Why bother bevan? plenty of cheap wheels around in 4x100 already. redrilling requires precise alignment to work assuming enough meat in the centre (a 5x120 would probably leave enough room depending on the design) and would not be inexpensive. get it wrong and you would throw the wheel away. It is done occasionally, usually for historic race cars where original wheels are no longer made, and the holes are generally welded first then redrilled, with the wheel undergoing fresh heat treatment and crack detection prior to use. V expensive....
Bevan
Postby Bevan » Wed Jun 21, 2006 3:34 pm
Well, as a great man once said... F*/K THAT! :P
Bevan
Postby Bevan » Wed Jun 21, 2006 3:39 pm
bigdog wrote:Why bother bevan? plenty of cheap wheels around in 4x100 already.
Oh, and let me know if you come across any. Look doesn't really matter, just as long as they fit. :)
CT
Postby CT » Wed Jun 21, 2006 9:37 pm
Look for BSA wheels, Speedy wheels, Alt wheels, GMAX wheels.........just to name a few :) I've got new wheels for $100 each just by asking around at local Bob Janes for example.:)
Sean
Postby Sean » Mon Jun 26, 2006 9:25 pm
