I'm in the process of puttin NB8B/C calipers on the blue car and am missing the 4 anti-rattle clips off the pads.
Mazda will only sell them with new calipers and at $2100 a pair I said thanks but no thanks.
I've tried 4 Mazda service departments that all say no we don't have any. And I've called numerous wreckers all of whom won't split the calipers they have.
I was also short 2 front clips that luckly I was able to get from one of Dick Richeys mates, but alas no clips for the rear.
If anyone has some clips floating around their shed (maybe from old siezed calipers) and would be prepared to part with them I would be forever indebted.
For that matter if anyone is going to a service department could you ask your local service guys if they have any.
Unfortunately I don't know what they look like as the calipers I have didn't come with any at all. All I know is the old NB8A clips don't work in the new NB8B/C calipers.
Any leads or help would be appreciated.
Thanks
Wòó
Anti-rattle clips have me rattled !!!!
- Woo
- Vehicle: 10AE - Turbo
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
- Russellb
- RIP Nov 2014
If you buy genuine pads you get new rattle clips ECT
I think i might have a few lying around
My ClubmanRebuild
MX5 SE Rally car is HERE
- Woo
If you could have a look for me Russell, that would be great. Thanks.
EDIT** In answer to the deleted post
, the \"squealers\" are on the back of the pad, then looping back around the side. I can understand why you would take them off, the blue car did a further 30000 k's after the fronts started squealing.
The clips I'm in need of are not the squealers. The anti-rattle clips sit between the alignment slots on the pads and the matching grooves on the sides of the caliper.
Some brake people say you can run without the anti-rattle clips on the front, however as the e-brake is on the back the clunking can be a bit disconcerting and they recommend fitting them. **/EDIT
http://www.mx5parts.co.uk sell a kit with them
anti rattle clips
Had the similar problem,no anti rattle clips in one front caliper.
Mazda said no way and brake centre could not source.
Alternative solution from local brake specialist is a sheet of of what looks like thick self adhesive vinyl.Cleaned back of pad applied vinyl and trimmed to pad shape.Problem solved no pad rattle and total cost $12.00
Fozzie
Fozzie
- bigdog
- King of the kennel
- Russellb
- RIP Nov 2014
I had a look today and I have no clips I have about 20 sets of front clips but no rear ones Sorry
My ClubmanRebuild
- Woo
Cheers for looking Russell, you'll probably be inundated with people looking for front clips now.
Thanks for the feedback guys
Okibi, the url you posted doesn't help mate, they are for the stock brakes and are the same as the ones I have (NB8A or non-sport B/C).
Well I fitted them up on the wheel without any clips and with the e-brake on the car can be rocked back and forth about 30mm with a loud clunk at the extremes.
I don't mind them rattling during application, but at a standstill I'm not convinced they should be left off.
The hunt continues
The hunt continues
- Brad
- rain902
bigdog wrote:You can buy a heat proof rubbery solution in a bottle (PRB Product from memory) from brake shops to cure pad rattle - apply to back of pad then fit. Used to use it on my Alfasud brakes.
alfasud brakes. Aaaah memories of inboard smoke and fire! went to 16v 33 vented (and slotted) outboards and brake fade is now a distant memory...
the stuff you are talking about works well - always used it on the alfas and my work cars.
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
- Woo
Users browsing this forum: No registered users and 146 guests
