I fitted the standard King/Koni combo a year or so ago - went for middle perch at front and lowest perch at rear as seemed to be the consensus at the time
now after settling in, the car seems a little dropped in the rear compared with the front and I want to raise the rear perch to level the car out again
Is this as easy as jacking the car, removing the wheel, using a spring compressor to remove the pressure on the spring base and perch circlip, pulling the circlip out and placing at the new height, then putting everthing back?
Sounds too simple, but I sure hope that is all that is needed - I can do it myself then and save some dollars
How to raise rear height with King/Koni combo
- JoshB
- Learner Driver
Gone but not forgotten
- Russellb
- RIP Nov 2014
I Know it sound too easy but You got it in one
My ClubmanRebuild
MX5 SE Rally car is HERE
Users browsing this forum: No registered users and 156 guests
