pressure of stock spare NA6
Posted: Tue May 09, 2006 11:54 am
by Shadow
anyone know what the pressures supposed to be for the stock spare from the 90NA6 is?
the wheel say 4.2kg/cm^2, which is 59.xx psi. have i done this right?? it seems excessive to me.
Shadow
Posted: Tue May 09, 2006 12:35 pm
by Garry
60PSI is good. Just make sure you check it regularly. Those space savers dont hold the pressure very well. After 3 months mine are normally down to around 40PSI.
Posted: Tue May 09, 2006 6:23 pm
by Shadow
cheers, thought i should pump it up just in case for that bathurst run soon.
better safe than sorry. it hasn't been inflated since i bought the car :P
Posted: Tue May 09, 2006 7:06 pm
by kitkat
it should say on the tyre but yeah 60psi will be just fine.
