Steering Rack Poly Bushes Question
Posted: Tue May 02, 2006 12:52 am
by Brad
I just got these non-PS steering rack bushes from Fulcrum and am wondering how I fit them. The one on the left seems easy enough as it's split to allow easy install, however the one on the right isn't split and would require the removal of the rack it would seem. I've had a look at the ones on the rack and it looks to me like the right hand one is for the passengers side and vice versa. Is this right?
Brad
Posted: Thu May 04, 2006 9:02 pm
by red63sprint
I have no idea - but tell us if they make a difference.
Posted: Thu May 04, 2006 9:33 pm
by Brad
Tell me, can anyone see the pics? I'm hosting them locally and I don't think my server is working properly.
Re: Steering Rack Poly Bushes Question
Posted: Thu May 04, 2006 9:45 pm
by StanTheMan
double post
by StanTheMan
not working for me......are they offline at the moment?
adress seems a bit strange.
I can host them for you temporarily
Posted: Fri May 05, 2006 12:29 am
by Brad
I had to shut down my main web server for a while so I just installed IIS to tie me over. I can see them locally of course but can't check to see if they are live.
How about now, I was running windows firewall and have opened Port 80 on it.
Edit: Ok, at work now so I can see they are up. Hopefully some help will come in.
Posted: Sat May 06, 2006 11:53 am
by red63sprint
What did Fulcrum advise when you called them???
Posted: Sat May 06, 2006 4:15 pm
by Andrew
Lube them up and push them in
Pic's from Matty's suspension bush install day -
link (may or may not help)
Posted: Sat May 06, 2006 7:30 pm
by Brad
Thanks Andrew, but there are the steering rack bushes, not the control arm bushes, which I've had done anyway. I sent the arms to Fulcrum to press the bushes in/out and fitted the arms back in myself.
