hi all
if any one knows whether 94 factory clubman spings
are the exact same specs as 90 na
i want factory ride height
thanks in advance
micksta
are factory 94 clubman springs the same specs as 90 na
90 ltd edition
Re: are factory 94 clubman springs the same specs as 90 na
micksta wrote:any one know whether 94 factory clubman spings are the exact same specs as 90 na? i want factory ride height
clubman springs aren't the same spec as the '90 na6 - they're firmer & apparently the bilsteins have a slightly lower spring perch meaning clubmans sit a cm or so lower - see thread below:
http://www.aus-cartalk.com/viewtopic.php?t=16845
I'm not sure
The standard ones lower 35mm
http://www.koni.com/konisport/frames/main_products_1130.html
The height adjustable page only shows their lowest setting (distance from stock height)
http://www.koni.com/konisport/frames/main_products_1150.html
Sorry can't be more help
- Brad
- Vehicle: NA8 - Turbo
- red63sprint
If its an old car the standard springs it will have dropped a bit anyway - people who lower thier car with old springs are often surprised it hasnt made much difference.
My Clubman has stock springs and shocks and has a hell of a lot of clearance...
1993 Clubman, Mx5plus roll bar
Autotechnica seats, Revalved Bilsteins
Fatcat Motorsport adjustable suspension
Espilier springs, Whiteline front bar.
Users browsing this forum: No registered users and 149 guests
