Tyre pressures
- Vehicle: 10AE
This topic generates plenty of interest, and opinions can differ significantly.
A popular pressure for street use [including some spirited driving] is 32psi cold, for both front & rear. This is a good starting point and allows you to experiment by altering pressures +/- depending on handling characteristics.
Happy 10AE man [#5128]
- jules
- Guitar Hero
- Charlie Brown
40psi cold
on the road will shake the s**t out of your car.
We don’t go that high for track days. Anything over 41 - 42 hot, the performance of the tyre drops considerably.
Most will use 30 - 32 for spirited street driving, especially not having smooth black tops in Sydney. For the track try 36 - 37 cold and monitor the pressure after each run so as not to exceed 40 – 41.
If you look on the sidewall of your tyres you will see a warning to the tyre fitters not to exceed 40psi when setting the bead. It’s put there for a reason.
- StanTheMan
kula wrote:i run my azenis RT615s at 28 allround..
same here...except mine are oly the RT215's
- red63sprint
- Red Baron
Road tyres on the road, 34 front 32 rear.
Typr R, depends what you might be getting up to, but because you probably won't generate temps 30 all round.
baron
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
Col wrote:This topic generates plenty of interest, and opinions can differ significantly. A popular pressure for street use [including some spirited driving] is 32psi cold, for both front & rear. This is a good starting point and allows you to experiment by altering pressures +/- depending on handling characteristics.
indeed - the only variation to the above i use is 30psi cold in summer
- Brad
- hugh_ness
- Vehicle: ND - 2
- red63sprint
- Brad
- RobbieRat
