Help with front suspension
Swizzel
Postby Swizzel » Sun Apr 02, 2006 7:22 pm
Hi guys,
I'm looking for some advice/tips on removing the front coil over from an na6 mx5. I need to take the whole unit out. I understand there are a couple of different methods: 1- removing the ball joint from the upper wishbone, then the bolt on the lower wishbone.
2- removing the lower wishbone bolts (including wishbone tongue bolt)
and then pressing the wishbone down to create some space and removing the shock through the upper wishbone.
Any advice or tips would be very useful. Cheers
White '93, a few mods.
\"Every K over is a killer.......Maybe do some exercise then before you get hurt!!\"
Swizzel
Postby Swizzel » Sun Apr 02, 2006 10:11 pm
sorted... Cheers though.
Shock is out, too easy!!!
