My New Tein SS!!!
- Brad
My New Tein SS!!!
They just turned up at work, now I want to go home to put them in.
Very shinny and green, they'd make a great wall piece. Even got a Tein hat thrown in for good measure, plus it came with about 100 stickers which will look great plastered all over the car...not. I did get a nice bubble type decal similar to the Clubman one might might go somewhere. Will keep updates on how the install goes and how they feel on the road.
- godfather of saké
Good work!
BTW if you got the version that comes with the top mounts, check that the nut holding the shock rod is tight. There have been some cases where it is loose. Also if you got the little can of anti-rust spray with the shocks, use that like holy water, it will stop the alloy spring perch from corroding to the steel shock body.
- Brad
- godfather of saké
Brad wrote:Thanks Bab. Yes, they have the top mount already assembled ready to drop straight in so I'll check that nut. Anti-rust spray... Supercheap?
To be honest the Tein spray looks feels and smells very much like WD40 to me...
Babalouie wrote:BTW if you got the version that comes with the top mounts, check that the nut holding the shock rod is tight. There have been some cases where it is loose.
Kevin, u didn't tell me when i got mine.........
but i guess mine is alright given it's been in there a while and no problem.
- godfather of saké
Philip Lee wrote:Babalouie wrote:BTW if you got the version that comes with the top mounts, check that the nut holding the shock rod is tight. There have been some cases where it is loose.
It's just something I've heard from a few ppl very recently. But when I checked mine it was fine.
- Brad
- godfather of saké
Brad wrote:It's written in big letters on the top of the box "Please tighten nut, spring seat and spring seat lock before installing"
Pfft...no one reads the instructions mate
- Brad
Re: My New Tein SS!!!
Brad wrote:They just turned up at work, now I want to go home to put them in..
By saying home I take it you mean my home/guarge?
Neil
SP Race Car
RS Clio
ML 300
RS Clio
ML 300
- Brad
- Cal
- Brad
Cal wrote:I can't figure out why you don't just change them on the carpet where that photo is taken.
Cal.
Cause I'd get a smack
