were can i find a on car balancer
StanTheMan
Postby StanTheMan » Mon Mar 13, 2006 11:21 pm
yes
wheel allingment & ballance.
torque the wheels correctly & experiment with pressures
rear lower chassis brace.
front lower chasis brace
if its still there
Add the Brown Davies roll bar.
if that doesnt get ridd of it.....
Konis & kings.
try the cheap remedies first. work your way towards the more expensive ones....... if its still there
1.8 Diff conversion with LSD
Turbo
errrr....just kidding
last but not least....find the 1985 Brock Polariser :lol:
Inf3ct0R
Postby Inf3ct0R » Mon Mar 13, 2006 11:28 pm
dude, just get rid of the crapy tyre at the rear if you have any, and balance, I had the shimmy with retreads, balancing retreads/crappy tyres doesnt work.
Babalouie
godfather of saké
Postby Babalouie » Tue Mar 14, 2006 3:46 am
I think the Bridgestone Tyre Centre at Artarmon on Pac Hwy (just near Scotts Honda) has an on-car balancer.
At least they used to....
Curly
Postby Curly » Tue Mar 14, 2006 4:48 am
Since I fitted the Mania chassis braces front and rear, I haven't felt the shimmy once...
Was hoping the whole car would feel a bit more solid, but I think I've got some bushes that need replacing in the front end.
Garry
Postby Garry » Tue Mar 14, 2006 9:13 am
Are your wheels located by the hub or only the wheel studs? If you are relying on the wheel studs then the wheels could be slightly off centre.
mickfred
Postby mickfred » Tue Mar 14, 2006 2:12 pm
I had this with my 17" wheels, then when I got my new wheels and tyres from Bob Jane in melbourne, I still had it and was really pi$$ed off. I went back to Bob Jane with an article from the US guys and explained it to them. They showed the allignment guy and he said , no worries, I'll have a crack at it for ya. He took all tyres off and balanced the wheels , then put the tyres back on and rebalanced it all together, then did the allignment again and it was PERFECT! I was so happy........... now after my allignment from Bob Jane up here in Brissy, the shimmy is back again :(
time to dig out another article :(
YEAH BABY!
JBT
Postby JBT » Tue Mar 14, 2006 2:42 pm
Interesting what Mickfred says. My case (NA8 not NA6) regarding the 100-105km/hr shakes:
1. Car was a bit shakey when bought but had original suspension and wheels.
2. New suspension (Kings/Konis) and alignment by Fulcrum - no more shakes.
3. Alignment changed by dickheads when car was repaired after bingle - shakes. 1 day later, re-aligned by another mob under warranty - less shakes.
4. 1 week later, new A539s fitted to original wheels and balanced (no alignment) by Bob Jane here - sssshhhhhaaaakes.
5. 1 week later, re-balanced and aligned by Fulcrum (15,000km ago now) - no more shakes and smooth as.
6. NB 15" wheels/tyres (ex Craig) fitted, no re-balance - no shakes, still smooth.
Go figure :? . It seems that balance and alignment affect it.
Garry
Postby Garry » Tue Mar 14, 2006 4:00 pm
I had a balance problem with the Direzzas. Several attempts at balancing didn't help, the last attempt at Spinning Wheel picked up an out of round tyre. They took the tyre off the rim and mounted it in a different location and all was fixed. Three other tyre establishments failed to pick it up even though I explained that the wheels had just been balanced and I still had vibes. :roll:
Benny
Postby Benny » Wed Mar 15, 2006 3:16 pm
Heasmans Steering in Sydneham does very good on-car balancing.
When I was there once, there was a guy who drove all the way from Newcastle to get an on-car balance.
Seems he had a slightly bent rear axle and Heasmans could fix the shake with an on-car balance.
I've been using them for years, probably since before many of you were born, and I've never had any shaking or shimmying on my cars.
Even the ones with bent wheels!
