HELP! Cant separate upper A arm from hub!
- Boyracer
- MX-5 Encyclopedia
- godfather of saké
Why don't you remove the bottom instead?
Leave the ball joint attached to the upright, and remove the bolt that holds the upright to the lower arm. Unbolt the shock, prise the lower arm down a bit and you will see a second bolt hidden inside the arm. Undo that bolt and the upright will slide out of the lower arm without removing either balljoint.
Of course if you've buggered one of the boots it'll have to be sorted eventually
- godfather of saké
V-Spec wrote:Any clues on how I'm going to separate the upper A arm from the hub? Seeing as though I got impatient, used the fork and busted up that upper boot, it looks like it's going to need replacing in the near future.
Yeah.....you give it to a mechanic, and then walk very far away so that you can't hear the sounds he will make when he hits it with a really big hammer
- Matty
- Boyracer
- MX-5 Encyclopedia
- Garry
- godfather of saké
- godfather of saké
V-Spec wrote:If I wind the helper spring up will that raise the ride height?
Anything that changes the pre laod on either of the springs will change the ride height.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
