caster
mmx005
caster
Postby mmx005 » Wed Feb 22, 2006 9:34 pm
just wondering if any one has played with their caster settings (assuming it is possible to do so)
Charlie Brown
Postby Charlie Brown » Wed Feb 22, 2006 9:54 pm
Yes, what model do you have?
For NA & NBs try for the maximum you can. ie around the high 4 to early 5 degrees with 1.5 neg camber. Back off the camber and the castor can go up.
If it's a NC set at around 6.2 degrees.
mmx005
Postby mmx005 » Wed Feb 22, 2006 10:00 pm
its for a 98 daily driver. im going to pedders on friday to have everything set up, and just wondered what caster (and everything else now i think of it) people had. is caster adjustment available straight from the factory or do you have to put a kit on the car???
Matty
Postby Matty » Thu Feb 23, 2006 8:49 am
With power steering, just pick the camber you want, then ask them to dial in as much caster as possible while keeping that camber angle.
Garry
Postby Garry » Thu Feb 23, 2006 9:22 am
It adjustable with the factory adjustments already built into the car, but it's not an independent adjustment. ie changing caster will also affect your camber. So it's a bit of a compromise between whether you want lots of caster or lots of camber. Hence the comments from the guys above.
Charlie Brown
Postby Charlie Brown » Thu Feb 23, 2006 1:02 pm
mmx005 wrote:its for a 98 daily driver. im going to pedders on friday to have everything set up, and just wondered what caster (and everything else now i think of it) people had. is caster adjustment available straight from the factory or do you have to put a kit on the car???
mmx005, see here.
http://www.aus-cartalk.com/viewtopic.php?t=15398
Users browsing this forum: No registered users and 143 guests
