ok, im a little against upgrading sways,
so who is running what?
atm i have clubman bilstiens, but should have cusco adjustable coilovers soon
stock sways on my NA6.
do people recommend the upgrade of sway bars?
sway bars - who is running what
- Matty
- Matty
- sab
- RobbieRat
- RRdstr
- RobbieRat
but my baby doesn't go on the track
Sorry Rex thats just not good enough Its high time your baby had the caining she deserves
There's a Rex day at the Island on the 11.3.06, it'll be the best day you've ever had and its the only real way of finding the limits of yourself and car.
Hope to see you there
- RRdstr
- RobbieRat
- StanTheMan
RRdstr wrote:I replaced the stock 19mm front sway on my NA with a 22mm NB one . . . left the rear stock.
Does all I want from it . . . but my baby doesn't go on the track . . .
I've done the same. But mine started understeeing like a pig. had to do some re-adjusting of shock absober Damping & tyre pressures.
I thought it was sweeter before.
- RRdstr
StanTheMan wrote:RRdstr wrote:I replaced the stock 19mm front sway on my NA with a 22mm NB one . . . left the rear stock.
Stan,
I run about 32 psi when driving in a "spirited " fashion . . . on 14" road tyres . .
I find that if I go into a corner tentatively, it feels like my baby is "thinking" about understeering, but as soon as I "put in the boot", she digs in and comes around like she is enjoying it as much as I am . . . I really like it set up that way . . . might not suit everyone . . .
Rex
- StanTheMan
RRdstr wrote:StanTheMan wrote:RRdstr wrote:I replaced the stock 19mm front sway on my NA with a 22mm NB one . . . left the rear stock.
Stan,
hey RRdstr....I would never dream of critisising anyones preference to set up of suspension. I f you are happy with your set up....nothing else matteres
I likedmy suspension set up the way the car was ballanced before the front sway bar change....Just had to do some mucking around to get it back to similar ballance after the change ....with the added bonus of having less body roll.
I had a pretty agressive allingment & pretty sticky road tyres to begin with. I also run 15" tyres. increased the tyre pressure in the rear decreased it in the front. did the same with the damping
each to thier own. maybe i should invest in the rear bar as well.....thats all.
Users browsing this forum: No registered users and 161 guests
