NB rear sub frame fit NA ?
- CT
They do directly bolt up. However, much easier getting tabs welded on yours I would have thought. Either way your going to need to get the car right off the ground for a start. To change the cradle you've got to pull the driveshafts, diff, undo all the brake lines, handbrake cables etc. That's hours of work. Welding on a few tabs is literally an hour or two max.
- StanTheMan
