Rolling Sans Suspension..
- Sean
Can anyone confirm if an NA car can be moved with no suspension in it. As in pushed around and the like?
- CT
- Sean
CT wrote:Not unless you put a spacer such as some solid wood between the A-Arms or even between the LCA and the upper shock mount - that's how I did it. Sounds like lots of fun
Cheers CT,
I knew someone had done it with wood. Ah well, time to go chop some wood...
Users browsing this forum: No registered users and 170 guests
