Brake rotor cover things
maxwolfie
Postby maxwolfie » Fri Jan 27, 2006 1:31 pm
Hey guys, I'm pretty certain that my brake rotor cover things are causing all the rattling in my car..
Are these safe to remove/bend?
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
Bevan
Postby Bevan » Fri Jan 27, 2006 1:33 pm
Yeah. They're just stone guards.
Take them off, see if noise goes away, if it doesn't chuck em back on! :) Let us know how you go.
maxwolfie
Postby maxwolfie » Fri Jan 27, 2006 3:16 pm
Cheers, I know alot of others have this prob too so I'll let ya's know
How hard are they to take off?
'89 JDM NA6 (black)
StanTheMan
Postby StanTheMan » Fri Jan 27, 2006 5:25 pm
Taking them off is easie.....set of wire cutters.
I believe the wheel bearing needs to be removed to get it off in one Piece.
1 look & you will know.
pretty sure thats how it is. maybe you can confirm this.
Russellb
RIP Nov 2014
Postby Russellb » Fri Jan 27, 2006 5:56 pm
To remove Stone guards first remove wheel then remove brake caliper
then slip the disc off . take the dust cap off the center of the hub . undo the wheel bearing nut . slip off hub then undo 3 10mm head bolts remove
stone guard assemble in revese order . front wheel bearing torque is
123- 159 ft-lb 167 - 216 Nm should take 1/2 hr per corner
