Spray paint or powder coat the wheels?
I want a bronze-ish finish to my standard silver alloys. Should i spray paint them or powder coat them? Anyone done this before?
- pcmx5
- Vehicle: ND - 2
Depending on the result you are after, powdercoating may not be the way to go.
If you are looking for depth and shine, especially in a metallic finsh, you would be better off spending the money on spraying in two pack.
If your looking for a long lasting satin finish then powdercoating is the way to go.
I've seen wheels powdercoated that were supposed to be copper /bronze but came out more looking like brown.
You could probably get broken old rim from the wreckers for nothing and use it as a test. spend the forty bucks to get it powdercoated and check to see if your happy with the result.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
- Red Baron
I have a set of rims that were 2 packed in white, use them for track with DO1's, they get heavy brake dust and all the other crap off the track.
A little Meguiars and they come up beautifully.
Powdercoating while durable is also brittle, so I think it would be prone to chip on a wheel, where 2 pack has not.
My experience
baron
My experience
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
- adamjp
I just refinished some wheels using the new Holts Duplicolour wheel paint.
http://www.duplicolor.com/projects/howto_wheel.html
You cannot get the damn clear in this country yet.
The big lesson that I re-learnt is that you need to strip the old paint/primer/filler off the wheels in order to have it look good. I didn't quite get it all off and they look like crap up close. Still, it was a learning experience, and I learnt.
No idea how the duplicolour will age, but since it is a polyurethane, it should be as tough as hell. It went on over etch primer, so it ain't coming off anytime soon.
Adam
ncmx5 wrote:well, i would like a gun metal grey against a red car. im still not sure.
Like mine?:
- adamjp
The paint is about $16 a can. 2 cans will be enough for 4 rims. Etch primer is around $15 and one can is enough.
The key is to get the old paint, etc. off. Try a bead blaster or professional paint stripper.
Adam
- green_comet
- Car Detailing Guru
Users browsing this forum: No registered users and 161 guests
