Sway bars which is best???
Spranga
Postby Spranga » Mon Dec 19, 2005 9:52 am
I want front and rear adj. swaybars. Any thoughts on which are best? I am thinking of getting whiteline bars from Mania.
Any opinions would be appreciated.
CT
Postby CT » Mon Dec 19, 2005 12:51 pm
We use them on the race cars so they work well. Cheaper than the imported ones and probably similarly balanced when adjusted to suit the car. 8)
Spranga
Postby Spranga » Mon Dec 19, 2005 1:43 pm
Thanks for the advice CT. Any advice on the best track setting...or is this a racers secret?
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Mon Dec 19, 2005 5:37 pm
Best just to get the front bar and try that first,don't really need to go to a stiff bar on the rear.
Spranga
Postby Spranga » Mon Dec 19, 2005 7:03 pm
Boyracer wrote:Best just to get the front bar and try that first,don't really need to go to a stiff bar on the rear.
Why is that Lou? Traction probs? I have actually ordered both this afternoon so maybe I will leave the rear one loose to start with.
Also I ahve just realised that I did not state whether I wanted the 16mm or the 24mm. What do you reckon is best for an occasional track car? I was thinking that 24mm would be OK given they are adjustable.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Tue Dec 20, 2005 8:37 am
Mx5s tend to be a bit oversteery....stiffen up the rear and it just makes that worse...
24mm is usually the front size and the rear would be 16mm.
Garry
Postby Garry » Tue Dec 20, 2005 9:04 am
I ditched the rear Whiteline adjustable 16mm and got a 14mm made up instead. Much better. I found it to understeery with the 24mm Whiteline front bar and stock 12mm rear bar, especially in the wet.
Craig
Postby Craig » Tue Dec 20, 2005 9:54 am
NFI what brand mine were as such, as EastCoast Suspension fitted them, but they were 3mm larger front and rear, and it was spot on for neutral handling. Some people report taily handling but maybe all bars aint the same? :mrgreen:
Spranga
Postby Spranga » Tue Dec 20, 2005 9:58 am
Thanks for the advice Garry, Lou and Craig. Sounds like I will need to do some experimentation to find my most preferred set up. A few laps of the putty road perhaps...all in the name of science 8) .
Matty
Postby Matty » Tue Dec 20, 2005 12:41 pm
Garry wrote:I ditched the rear Whiteline adjustable 16mm and got a 14mm made up instead. Much better. I found it to understeery with the 24mm Whiteline front bar and stock 12mm rear bar, especially in the wet.
Garry - who made your 14mm bar?
Garry
Postby Garry » Tue Dec 20, 2005 3:47 pm
KMac. Their factory is on the way home from work. The'll do any size you want.
Matty
Postby Matty » Tue Dec 20, 2005 4:13 pm
cool. I'm considering one if I go to 3kg rear springs.
is it orange?
irwin83r
Postby irwin83r » Tue Jan 10, 2006 9:55 pm
matty you know they sell paint thats orange right? :D
or do orange bars mean something? :|
i'm hopeing to get some white lines soon, though im not sure if i should get adjustables. they worth the while or is a solid pretty good any way?
Postby Okibi » Wed Jan 11, 2006 1:24 am
I'm happy with my racingbear (both front and rear) but i haven't been able to give them serious track time yet.
Users browsing this forum: No registered users and 57 guests
