underbody brace
Me
underbody brace
Postby Me » Wed Nov 30, 2005 7:46 pm
hi,
as you might aware of my previous post was removed. i am reposting it as i dont have the answer yet. could someone please tell me where the underbody brace is supposed to put in for my 89 na6? i have tried to put in the front but the brace is too long for the inner holes. the bolts r also too small for the holes...
my new brace:
http://memimage.cardomain.net/member_im ... 2_full.jpg
the under body (not my car)
http://memimage.cardomain.net/member_im ... 9_full.jpg
Matty
Postby Matty » Wed Nov 30, 2005 8:49 pm
where did you get it from and what's off?
It looks a bit like the OEM rear brace, but you'd need the mounting tabs welded onto your subframe for it to work.
Me
Postby Me » Wed Nov 30, 2005 9:21 pm
it's from another forum member in Adelaide or ACT (i dont remember). he claimed it is the front brace but i believe it is not. what r the mounting tabs look like? is it possible to purchase them separately?
Juffa
Postby Juffa » Wed Nov 30, 2005 9:26 pm
While it does look like a rear brace, it also looks like the factory brace in this scan from a Haynes manual.
The brace is located near the number 6. Not all early models came with the holes for the brace. Also the holes need to have captured nuts behind them to screw the bolts into.
J
Juffa
Postby Juffa » Wed Nov 30, 2005 9:35 pm
Me wrote:it's from another forum member in Adelaide or ACT (i dont remember). he claimed it is the front brace but i believe it is not. what r the mounting tabs look like? is it possible to purchase them separately?
On the early early 5s there was no rear brace. Companies such as the MX-5 Factory in Melb made their own, such as the red one in this photo. The two mounting points need to be welded on to the rear subframe.
J
Me
Postby Me » Wed Nov 30, 2005 9:45 pm
my car does not have the extra holes in the front. that might be the problem. could i have a look at someone's underbody in the next dodge brother day?
adamjp
Postby adamjp » Wed Nov 30, 2005 10:03 pm
That looks like a rear subframe brace that is bolted to the subframe by using the rear adjustment bolts of the lower A arm.
My aftermarket JDM bar uses the same bolts.
The picture that Juffa brought to the fore is also convincing. My front brace bolts a little further back.
The key part about fitting the rear bar is to mark the adjustment of the bolts so they can go back in with the same adjustment.
Adam
jp928
Postby jp928 » Sun Dec 04, 2005 4:28 pm
If you look at the Haynes pic posted by juffa, you will see a pattern of 3 holes (one larger central one with smaller ones on each side) just inboard of the rear lower arm pivot. I have an aftermarket brace bar that is just a piece of steel tube with the ends flattened, and drilled at the spacing between the large holes from one side to the other. They come with a nut that you manoeuver into the channel(bit tricky), and you hold the nut with a spanner under the lower arm inner end. It would be easier to get a piece of ~4mm steel plate that will fit in the channel, but cant turn, drill and tap it (M8?) , slide it into channel, and just screw into it.
jp 92red
Juffa
Postby Juffa » Sun Dec 04, 2005 8:30 pm
jp928 wrote:If you look at the Haynes pic posted by juffa, you will see a pattern of 3 holes (one larger central one with smaller ones on each side) just inboard of the rear lower arm pivot. I have an aftermarket brace bar that is just a piece of steel tube with the ends flattened, and drilled at the spacing between the large holes from one side to the other. They come with a nut that you manoeuver into the channel(bit tricky), and you hold the nut with a spanner under the lower arm inner end. It would be easier to get a piece of ~4mm steel plate that will fit in the channel, but cant turn, drill and tap it (M8?) , slide it into channel, and just screw into it.
jp 92red
I have a front brace from the MX-5 Factory that fits as exactly you described. It uses a plate with two threaded holes that the bolts scew into.
J
emecksphive
Postby emecksphive » Fri Dec 09, 2005 3:13 pm
I just recieved my mania braces what do i need to have done to fit these?
cheers,
JR
Me
Postby Me » Sat Dec 10, 2005 12:19 am
emecksphive wrote:I just recieved my mania braces what do i need to have done to fit these?
cheers,
JR
huh? isn't ur one a straight bolt-on?
emecksphive
Postby emecksphive » Sat Dec 10, 2005 6:16 pm
thats what im hoping, havent tried to fit them yet
namster
Postby namster » Wed Dec 14, 2005 10:15 am
damn.... :cry:
i jacked up my car yesterday with the trolley jack resting on those rails...
and it has bent the rail... not very strong!!
so, do these chassis braces really make a difference? their mounting points arent that strong.
zoom zoom zoom...
Me
Postby Me » Wed Jan 11, 2006 7:44 pm
i jacked up my car today. my car doesnt have the holes in the arrow #6. so i try it on holes #9. it fits perfitly. i am sure it is the front brace. however, the bolts r too small. i need bigger bolts. i tried 11/66 and 17mm wrench on the bolts. it is a little bit loose. any suggestion on finding the right bolts?
Me
Postby Me » Wed Jan 11, 2006 8:00 pm
jp 92red
J
is captured nuts the only thing i am missing? how much did u pay for ur install?
