Are we hub centric?
kazama
Re: Are we hub centric?
Postby kazama » Fri Mar 07, 2014 11:46 pm
project.r.racing wrote:
kazama wrote:949 racing doesnt stock them because theyre "not needed"
say what?
referring to the 15's
"You may notice there are no hub centering rings offered and there is a reason for that. Most aftermarket wheels use a generic 67 or 73 mm bore. The reason for that is to save money on tooling and machining setup time. Bigger 5 lug wheels use the big 67/73 bore so the smaller 4x100 pattern wheels get it whether it's optimum or not. The 6UL is only 59.1 which makes it a stronger and lighter wheel. Our experience is that centering rings are not needed to properly locate the wheel concentrically. "
timk
Postby timk » Sat Mar 08, 2014 8:12 am
If you tighten tapered nuts in a sane sequence the wheel will be centered correctly without the hubcentric ring. I've melted a set of plastic ones on the front at a track day and haven't bothered replacing them.
project.r.racing
Postby project.r.racing » Sat Mar 08, 2014 10:28 am
say what?
That is werid since my 15" 6ULs came with 949racing blue rings.
kazama
Postby kazama » Sat Mar 08, 2014 4:24 pm
project.r.racing wrote:That is werid since my 15" 6ULs came with 949racing blue rings.
lucky i guess :D
