Everything Frame Rail Brace Related
- Alex 2550
Re: Everything Frame Rail Brace Related
all my stuff arrived yesterday arvo
rails are almost too pretty to hide under the car lol
Retro NA8
build viewtopic.php?f=57&t=71923
- KevGoat
Well I'm finally all done with the rails from the group buy
Did the side with the fuel lines first as I knew it would be the painful one due to a huge knock that it had taken before I bought the car. Was the best part of 4 hours to get it back to a box like shape that the brace would fit over, but I got there in the end.
I forgot to take a start picture, but basically one small section of this rail was smashed up flat against the floor, which was a huge pain to get started on. This was after about an hour of work:
Not going to say I'm proud of my methods, but it got the job done in the end
- LiteIsRite
noisymime wrote:Well I'm finally all done with the rails from the group buy![]()
Interesting application of a vice
"Cherry" - Classic Red 1990 NA6
[sold]
I'm still trying to fix the drivers side rails and didn't think of using a vice to straighten them back into place.
If anyone has some other helpful tips on what I could do to fix them up, please let me know because I've been dying to fix these already
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
The Oem frame is easy to straighten if you have a welder. Weld some tabs to the bottom edges (or the crease that is supposed to be the bottom corners) and pull down on them with a slide hammer. Then cut the tabs back off. Clean it up with a grinder and paint it.
LiteIsRite wrote:noisymime wrote:Well I'm finally all done with the rails from the group buy![]()
Interesting application of a vice, noisy, and glad I didn't have an issue like that to deal with. Let us know your impressions after you have a decent drive.
Car is currently out of action for another week or 2 with other work (Took the opportunity to pull the carpet out and redo bits of the interior at the same time), but I'm hanging out to drive it as well!
The vice was a massive pain to work with (It's bloody heavy) but it did work really well. I couldn't get anywhere near enough force with clamps and things, but the vice helped a lot once I'd reach the point of having some room between the floor and the crease.
jko wrote:I'm still trying to fix the drivers side rails and didn't think of using a vice to straighten them back into place.
Bash them with a small sledge hammer. That’s what I did and it works and works fast as the metal is quite ductile.
Dehamsta wrote:jko wrote:I'm still trying to fix the drivers side rails and didn't think of using a vice to straighten them back into place.
it's quite difficult to do from the inside and there are fuel lines that are kind of in the way. I think I'll have to resort to some sort of clamping force to bend them back into shape again.
- bruce
- Vehicle: NA8 - Turbo
That squashed rail was really squashed.
My rails were only 10% as bad as those and the roadworthy guy wouldn't pass my car. I suspect my car had gone over too many ripple strips.
- Alex 2550
wow guys!!
there is some ugly pics there, what a pain to fix but i love the use of the vice!
my rails are as new not even a mark on the underbody coating so i guess im lucky, hoping to do mine on the weekend if work doesn't get in the way
ill also get the extra 2 short (m8x16mm) bolts LiteIsRite mentioned on friday
Retro NA8
- Gladiator
I got started on mine today. Only got the passenger side done though due to V8s being on.
Out of the box, everything was very well packed, & all components were there.
My rails weren’t too badly bent, so a few taps with a sledgehammer was all it took.
After that it was all pretty straight forward.
I have to say that I strongly disagree with the pilot hole idea, because if your pilot hole is off centre, so will be the 8mm hole. With good a quality drill bit, 8mm is not a big hole to drill. Spend the time getting the rail held in the correct position, then just drill one hole at each end & insert the bolts & nip up. Then you can just drill all the other 8mm holes.
- KevGoat
Yeah I did pilot holes and it was a stupid idea - had to drill out a number of holes, not by much but enough the bolts wouldn't go through ..... and damn!! just seeing your photo has jolted my memory that I didn't re-spray/seal those freshly drilled holes grrrrrrrr .......
- Gladiator
Don’t feel too bad Kev. I forgot to silicone around the holes.
- KevGoat
Yeah ... just wonder how long my ocd will hold out
