I want to remove ABS
davekmoore
Re: I want to remove ABS
Postby davekmoore » Sun Nov 16, 2014 8:40 am
roket52 wrote:Hi Angus, I got tired of all the whining in this thread so I thought I'd chime in and help you out with your answer.. I wondered the same thing as you about the abs kicking in too early on undulating surfaces, so guess what I tried?.. Pulling the fuse :shock: shock horror! It made the world of difference and now the braking response is much more linear than before over undulating surfaces and I can brake much harder with any unnecessary electronic interruption. I've been driving like this for almost a year and I have no regrets. Forget spending all your money on everything else people are suggesting just pull the fuse and try it.
Finally an answer which will suit Angus and must therefore be right.
Postby Magpie » Sun Nov 16, 2014 8:43 am
Come out to Morgan Park at the end of the month and try with without. One of the first events is a stop in the box skill. The amount of tyre smoke from non ABS cars is a telling sign and I'm yet to see threshold beat ABS, unless the non ABS car is going slower when it starts to brake.
MattR
Postby MattR » Sun Nov 16, 2014 11:42 am
Gotta have one more go......
The fact that you thought ABS stops you quicker means you are not worth listening too Matt! ABS is a back-up system for an incompetent driver or a situation which has been created due to being off guard and slamming the brake. Same with ESP. even when driving all the Toyota 86's I have dríven which is about 5 different ones, I have always found driving without ESP A LOT more predictable than driving with it on. and at the end of the day would a more predictable car be safer? (Now just so what I have said about the 86's ESP can't be taken out of context i will give some points here. The 86 is a low HP, low weight car which means in never has enough power to surprise you as a driver, very similar to an mx. I'm sure the use of ABS on in a high HP car is a completely different ball-game.)
So this is a road car so i'm not wanting to pull out the whole system as such I just don't want the ABS to kick in, I find it very upsetting when driving hard and i'm not used to it as both cars i've owned so far a pre 1992.
From your very first post you are saying you are finding that the ABS is kicking in when driving hard, so that tells me and others you are driving on public roads where you are at and beyond the maximum braking ability of your car.....
I did a mountain run the other day and i find it kicks in even when you aren't fully on the point of braking traction, like I could start to feel the pedal giving some small bumps (not as vigorous as when you completely slam on the brakes) but i knew there was a lot more in the tyres before they were going to break traction.
From your second post..... I don't know too many race tracks around a mountain up here that allow access at any time that I would call a controlled environment.
If you read what I said earlier.....
I have never said that ABS will stop a car quicker than threshold braking. ABS is a great safety system in that even when you have the brakes pressed at 10 out of 10 and the ABS has kicked in you will still have steering, something you don't have without ABS and a locked wheel.
WOW you've dríven 5 Toyata 86's, well I've only ever dríven one so you win, but to win the pissing competition, I did spend some time driving a 55AMG SLK, I have owned around 20 cars of varying performance but mostly quick 4's, both NA and turbo, plus some quick 6's and a couple of V8's.
ESP is there to help keep the car on its intended path by controlling the braking force on each wheel and/or the amount of power supplied to the dríven wheels, again if you are finding this is hindering your on road driving you are doing it wrong..... Underpowered or overpowered car.
On a track, well then there are some advantages to having the ESP not as intrusive or switched off.
As for my driving ability, I'll back it any day, as I also said, I am always learning how to drive better on the road and quicker on the track. I am lucky I get plenty of seat time in a controlled environment to practice all facets of my driving from basics such as posture and steering techniques through to controlling slides and emergency stops. My driver training has never stopped and I consider myself lucky that I was mentored by some great competition drivers in my teens who encouraged me to start driving on the track and get into competition driving, where I learnt a hell of a lot in terms of high performance driving skills that I don't use on the road, but also other skills that are needed on the road to be a better driver. The most important skill being vision, being able to read what is happening ahead and from that being a smoother driver for me and my passengers.
And now to answer a couple of questions on ABS.......
First, which will stop in the shorter distance, ABS or Threshold??????
Threshold braking will, but to do so is very difficult and takes a lot of practice to know the car well and also to obtain the skill and feel for your car to do it well, jump in another car and it will brake differently.
As it implies, threshold braking is using sufficient force to have the maximum braking force without locking the wheels, but being on the verge of locking the wheels. This provides the maximum grip between the tyre and road surfaces, therefore the highest levels of friction and the shortest possible distance to stop the vehicle.
With ABS, no matter what system, it allows the wheels to lock for a period of time. Early and cheaper systems this maybe for up to a 10th of a second or even longer depending on the electronic brain and the capabilities of the system to release brake pressure to the affected wheel and then reapply brake pressure. Also how many channels the ABS has, early falcon systems had 3 channel systems where the front brakes where individually controlled, but the rear brakes were both released if a rear wheel locked. In doing this the stopping distance will be longer than non ABS, as the brake pressure is constantly changes from full pressure, released and reapplied, depending the system from say 5 times a second to 30 times a second for high end vehicles.
In the real world with a car in good condition on a dry road with a good constant surface with a high skid resistance the distances from longest to shortest will generally be:
1. Locked brakes - car slides along the road, in conditions described above for a lot of cars only a couple of metres longer in a straight line
2. Lock and release - lock brakes, release some pressure to get wheels rolling again, generally not much shorter than full lock and slide, and if done with not a lot of skill can be a longer stopping distance than locked brakes.
3. ABS - In an emergency, what I would go for, don't have to think about my braking, let the technology do the work for me to pull up pretty quickly. I also have the biggest advantage that I will always have steering and basically full control on where the car will go.
4. Threshold braking - done well, will pull up a metre or two shorter than an ABS stop, but very hard to pull off properly. In an emergency situation you will find that you are overloaded with information and also panic so that it becomes very difficult to execute the braking with the finesse needed.
5. Good vision and awareness - use this, know what going on around you and ahead, don't just look at the car in front, look as far up the road as you can to see what is going on, keep a 2 second gap, more in bad conditions or if you have loaded the vehicle up with extra weight or you are driving an older car or 4WD set up more for off road than highway. With this you will see the situation and be able to make your decision in plenty of time and not need to worry about emergency stopping techniques.
In wet conditions the order is the same, but the distances are exaggerated greatly.
What does pulling the ABS fuse do????
As discussed in the thread, pulling the ABS fuse disables the ABS system. As the brakes are a mechanical system the usual operation of the brakes isn't affected, including the brake bias as determined by the factory or user depending on the components used and whether they have been modified.
What the ABS does is monitor the wheel speeds and if one wheel stops rotating whilst others are still rotating will send a signal to release the brake pressure to the brake controlling the wheel that has stopped rotating. Once the wheel rotates again, then the computer allows the full pressure as applied by the brake pedal to be applied to that brake again.
The ABS doesn't affect the performance of the mechanical braking system until it sensors a wheel has locked up. If the ABS is disconnected then the brakes will work as normal, just when a wheel stops rotating then there is nothing happening within the brake system to release the brake pressure so the wheel or wheels will lock.
But hey what do I know???? I'm just some old bloke with issues........
Those issues include:
Watching mates in the emergency services trying to cope with mental health issues from the carnage they see through stupidity on the roads.
Having lost a couple of mates at high school in car crashes.
Seeing families torn apart by someone else's actions on the road.
Seeing stupidity on the roads that just shouldn't be happening and could be easily fixed with a decent driving education system where getting a licence is a privilege rather than a right.
Government agencies taking the easy way out with road safety rather than tackling the lack of skill of most drivers.
I know young blokes are "young, dumb and full of cum" but doing the right thing on the road, ie not driving like a dick and taking it to the track to go your hardest is what you should be doing. Up here in Brisbane we are so lucky to have the easiest access to track time at QR and Lakeside, bugger all hoops to jump through, just fill out a form pay your moneys and you can play and go as fast as you want and discover how much talent you actually have as a driver.
zero00
Postby zero00 » Sun Nov 16, 2014 12:20 pm
Angus
Magpie said it - white NA last year fired off Glorious, luck to escape, and at least 2 others I know of with MX5's and one was FATAL around Mt Nebo so not nice. I have photos of the white one that fired off that I took at Automotive Plus but thru respect to the driver will not post here
With repect I know quite a few of those who have posted, two at least are race drivers who know cars backwards and have tried to give you advice and one of those two is a very experienced DRIVER TRAINER at several locations in SEQ
IMO I would suggest take the car to a brake EXPERT and have them check the ABS thoroughly as having had several cars with ABS I have never experienced what you seem to be. My 86 has ABS and has been up and down Bellthorpe Range, rather rough in places and very steep and under heavy braking has yet to activate the ABS
Roger D-SUNSHINE COAST
Hellmun
Postby Hellmun » Sun Nov 16, 2014 12:33 pm
Well I've got a 2001 Nb8B and I've dríven my car with the ABS disabled. When my car was last aligned my front right ABS sensor was accidentally severed by an over enthusiastic mechanic getting me camber. So I pulled the fuse to keep it from getting confused until I replaced it. The EBD (electronic brake force distribution) no longer works, so the balance shifts forward way too far. I'd say your talking %20-30 less pedal pressure for lock-up Vs previously where the ABS would engage. This was based on about 0.7G under brakes Vs 0.9 normally with the EDB brake biasing on KU31's. I have a datalogger with a live display (DL1 + Dash3) in the car and I am a bit of a data whore.
When you talk about ABS being unable to keep up with a person at the absolute limit it is true in a limited small number of scenario's. Hot dry surface with perfect brake bias I believe it's approximately %7-%10 if braking in a dead straight line? I think that was in Senna's book... maybe Ross Bentleys? I can't remember I've read a lot of driving technique books. Make it cold, wet, dirty or a poor surface (pretty much every road surface fits this category compared to race circuits) and ABS wins. Plus you will lose the safety buffer of the unexpected happening to you. That unexpected for example is the blind corner with gravel because of the lorry with a loose tray, the alfa romeo dropping oil along the fast line which wasn't there the last time you ran your little course. While these things happen rarely...they only need happen once to write a car off or worse drift you into an oncoming lane and a family laden vehicle. You won't be able to threshold brake even if you are the greatest born driver of all time as that pedal is connected to all 4 calipers at once unlike the ABS which can handle them independently.
Me I've been racing for years and I do actually intend on removing my stock master cylinder, putting in a tandem master cylinder with balance bar and getting that extra few percentages of threshold braking without the ABS one day. It's actually becomes a problem with destroying pads/rotors if you engage it when the brakes are north of 600C+. I will however keep the ABS and simply disable it via toggle switch so when the conditions aren't perfect I can turn it back on.
Do what you want mate but remember... the consequences of making the mistake may not only affect you.
angusis2fast4u
Postby angusis2fast4u » Sun Nov 16, 2014 12:34 pm
Magpie wrote:Give a motorcyclist a winding, mountain corner and they're in hog's heaven but sadly it comes with a price. Over the past 12 years, there have been 887 motor cycle accidents at Mt Glorious and Mt Nebo.
http://blogs.abc.net.au/queensland/2014/04/campaign-to-reduce-motorbike-fatalities-on-mt-nebo-and-mt-glorious.html.
I have had the displeasure of being at Automotive Plus one Saturday where a white MX5 had crashed on the Mt Glorious road, not pretty, driver ok car not.
It would appear that ABS on here is like uraniumn, it is polarising and it will never be solved at least on a forum. Simply we as drivers on public roads and the track for that matter drive to suit conditions. Tracks have no speed limits but that does not imply they are safe.
Like or dislike ABS it is a technology that has remained and not been a fad like 4 wheel steering. I have a day off today so time to find some empirical evidence on ABS and threshold braking.
+1 for taking the effort to look for facts before making a statement, unlike some others. I don't drive anywhere near my limits or the cars limits up in the mountains, I save that for the track, but I admit I drive spiritedly up there, but who here doesn't?
JBT wrote:
angusis2fast4u wrote:ABS is a back-up system for an incompetent driver or a situation which has been created due to being off guard and slamming the brake. Same with ESP.
Your ignorance is breath taking.
angusis2fast4u wrote:It could have actually been a very good educational thread on ABS and its effects but some people seem to have opinions which they cannot help sharing, and subsequently have ruined what could have been a really good thread with good information.
Yes, it could have....but not for you.
Rather than giving me an opinion, go and find some facts and give me an answer..
my first statment is completely true, ABS was designed so when people slam on the brake ( A) due to reaction - i.e. they haven't had time to think to find the threshold they have panicked and slammed on the brake and - this is why ABS is seen as being so safe, but will never be better than a manual system. B) I will give you some time to research about my statement about ESP - this is the perfect opportunity for you to come back with a useful answer!!)
The American wrote:Angus, if your dampers are really no good, you might be experiencing something caused by wheel tramp, and not premature ABS lock up. ABS would likely operate during wheel tramp, but the cause might be damper related rather than overly aggressive braking. If you're braking on a less than smooth surface, a dampers job is to prevent the wheel from bouncing clear of the road. If the damper isn't up to the job, the wheel can start to bounce. It's not uncommon to see wheels on truck trailers doing this when pulling up.
+ 1 for not disabling ABS on public roads. On the track, ABS is flat spot insurance (although good to learn to threshold brake without it). Maybe try with and without ABS via the fuse at your next track day. In the autotest events I've done, the ABS cars had a much easier time getting stopped in the 'garage' and non-ABS cars were much more likely to skid through and incur a 'Wrong Way'.
+ 1 for not finding the limits on public roads. If you're really at the limit, you will run off the road from time to time. On a track, this still comes with risks, but not to unsuspecting road users.
+ 1 for asking questions and learning about your machine.
+1 for a very well written and respectful post (This seems super hard to do on this forum, and isn't the mx5 community meant to be well known for its kindness - obviously not lol!)
I will definitely look into that Wheel tramp you are talking about as it does seem similar to what I have experienced
+1 for reading the post before commenting unlike matt
and Thank you for realizing that i'm trying to learn about this ABS issue
Sorry mate you seem to have a real attitude problem. I never said he was correct in his answer, I never said he was wrong in his answer either. I simply said THANKYOU for commenting as he obviously has experience in this area and could therefore contribute a lot to this conversation unlike you and matt who seem to have nothing but OPINIONS (NOT ANSWERS!!) Even Magpie is taking the time to do research to come up with the answer before he states an opinion, after he does his research, he is welcome to come back show me the facts and call me an idiot, but you and matt have shown you know jack all about the topic and still produce opinions ( I actually have a very high respect for you Magpie through your knowledge and ability to want to learn more about topics and give actual feedback from research)
gslender wrote:This forum has a high concentration of the Nanny-State voters... yah for rules!
100% agreed on the Nanny-State
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
Postby NitroDann » Sun Nov 16, 2014 12:41 pm
The early mx5 abs isn't a modern 4 channel inertia sensor equipped clever braking force ddistribution device it simply pulses a lock unlock condition.
It into comparable to abs on a new SLS amg or m3.
That's my 2c take it as you will.
angusis2fast4u
Postby angusis2fast4u » Sun Nov 16, 2014 12:50 pm
zero00 wrote:Angus
I am going to check over the suspension and then if it doesn't fix it I will take it to an ABS person (bold so that I don't have to post it again for like a 5th time)
Also i never said I activated ABS in an 86, even driving in the same conditions and same driving style as my mx5 when it likes to kick in (kick in lightly - not full abs which only happens under full pedal pressure and full wheel lockup)
Hellmun wrote:Well I've got a 2001 Nb8B and I've dríven my car with the ABS disabled. When my car was last aligned my front right ABS sensor was accidentally severed by an over enthusiastic mechanic getting me camber. So I pulled the fuse to keep it from getting confused until I replaced it. The EBD (electronic brake force distribution) no longer works, so the balance shifts forward way too far. I'd say your talking %20-30 less pedal pressure for lock-up Vs previously where the ABS would engage. This was based on about 0.7G under brakes Vs 0.9 normally with the EDB brake biasing on KU31's. I have a datalogger with a live display (DL1 + Dash3) in the car and I am a bit of a data whore.
As I said in the start of this thread as well, I would not do this if I needed to replace components (if disabling was as easy as pulling a fuse and had no other ramifications [which apparently it has]) I would consider it as an option. But I have learnt you need to replace stuff for the brakes to work at 100% So i have no interest in pulling the fuse. I wanted the system to be reversible so I could drive around normally with ABS on (insurance happy) and take it out on the track where I would feel a lot more confident being able to test the actual threshold.
plus if i bought a car a year earlier (2000 - the NB8A) this would not be seen as a big deal as they don't come with ABS but no one sees them as a pending death trap because they don't have ABS
Magpie wrote:Come out to Morgan Park at the end of the month and try with without. One of the first events is a stop in the box skill. The amount of tyre smoke from non ABS cars is a telling sign and I'm yet to see threshold beat ABS, unless the non ABS car is going slower when it starts to brake.
I would love to! can you please PM me a link to the details
~Angus
2001 Silver NB8B
Postby Magpie » Sun Nov 16, 2014 1:01 pm
http://mx5cartalk.com/forum/viewtopic.php?p=819516#p819516
SDT run a very good day, this will be my third with them. I just wish I was not away when they run courses.
Start of the session is a quick blast with a stop in the box at the end, do this twice. Then one of the shorter courses with instructors. Finally end of the session one of the longest tracks, they do not run the full track because of the speeds down some of the straights that can be achieved.
I'm not sure what time I'm leaving (having the dodgy day on the Sat) and if I will be towing the MX5 but your welcome to join the convoy :) Maybe I can get my other half to leave later and bring the trailer so I can drive...
MattR
Postby MattR » Sun Nov 16, 2014 1:04 pm
Link is here Angus, get the forms filled in and to me in the next couple of days if you want to have a go. I am more than happy to help you improve your driving and try things in a controlled environment.......
http://mx5cartalk.com/forum/viewtopic.php?f=71&t=65834
Postby Magpie » Sun Nov 16, 2014 1:07 pm
Including pulling the fuse on the ABS!
Another shameless plug for dodgy day http://mx5cartalk.com/forum/viewtopic.php?p=816577#p816577. I will set up a soap box and mike to discuss this topic whilst people eat hot chicken wings, bring your own over ripe tomatoes :)
zero00
Postby zero00 » Sun Nov 16, 2014 1:33 pm
I was deliberately polite you Angus, show a little politeness when you read each reply
Pretty simple thing to ask
See you Automotive Plus next Saturday 10-2 where you can forget this forum and ask the experts
angusis2fast4u
Postby angusis2fast4u » Sun Nov 16, 2014 2:21 pm
Magpie wrote:http://mx5cartalk.com/forum/viewtopic.php?p=819516#p819516
I've just read all the info on the thread and while i'd love to, i'd love to also get this suspension sorted before I take it out on a track and drive it at it's limits (thought it was just a skidpan day at first) and since I won't have 2800 for coilovers by the 30th I don't think I'll head out this time, but I promise the next one (when i have the suspension sorted) I will! plus I do go to morgan park frequently to watch my Uncle and cousin race so it will be nice to actually go out on the track after all these years!
~Angus
2001 Silver NB8B
zero00
Postby zero00 » Sun Nov 16, 2014 2:29 pm
Regardless of all things said on this topic Angus, you are always welcome to join the MX5 Club on track
Six [6] meets next year being 3 at QR and 3 at Lakeside
Obviously you have a particular type/brand of coilover in mind at $2,800 but many are around the $1,500 mark
Probably a good idea if you get the time to come to the Open Day at Automotive Plus next Saturday and enquire with those there that do 'track sprints' as to what they run and what they think of them
angusis2fast4u
Postby angusis2fast4u » Sun Nov 16, 2014 2:31 pm
zero00 wrote:I was deliberately polite you Angus, show a little politeness when you read each reply
Thanks,
No need to ask I have found the answer :D
Also you say "See you Automotive Plus next Saturday" Like i have met you before, have I?
Also the Coilovers at $2,800 are the MCA Reds - which I was told were well worth the extra $1,300 over the blues
(But am open to saving money if people say the blues are good enough :P
~Angus
2001 Silver NB8B
