Tein rattles
Re: Tein rattles
Postby bruce » Sat Sep 13, 2014 9:36 pm
RS2000 wrote:
Charlie Brown wrote:Here's a photo of the Tein Flex in my NC.
The base locking ring is undone to allow the whole shock to rotate inside the lower casing, to raise or lower the height.
sailaholic
Re: Tein rattles
Postby sailaholic » Sat Sep 13, 2014 9:44 pm
Yes change your ride height with preload.
Re: Tein rattles
Postby bruce » Sat Sep 13, 2014 9:52 pm
I've got Tein Flex. I thought the very bottom collar was ride height? Loosen that upwards, rotate the top section, lock down the bottom collar.
Re: Tein rattles
Postby bruce » Sun Sep 14, 2014 7:29 pm
I've checked youtube, other forums and I am doing it right (bottom collar (3rd collar), turn it anti-clockwise, following the thread)
The bottom collar just doesn't want to move! I've hit them with WD40 but no budgee.
project.r.racing
Re: Tein rattles
Postby project.r.racing » Sun Sep 14, 2014 8:03 pm
check there is not a tack weld on the backside of the collar.
Re: Tein rattles
Postby bruce » Sun Sep 14, 2014 8:16 pm
I will check. I even thought there might be an Allen key lock.
dmad_dood
Re: Tein rattles
Postby dmad_dood » Sun Sep 14, 2014 8:30 pm
Ive got tein monflex in my na8 and there driving me up the wall with the noise!!! I adjusted my preload the other day and it helped a bit and theres still that loud knocking noise. Almost sounds like the nuts that mount the top hats to the chassis are loose and when it unloads its slamming into the chassis. ive also tried tightening those shaft nuts but they spin freely?
Very interesting thread, hope you find the problem.
Jono.
Red NA8..
project.r.racing
Re: Tein rattles
Postby project.r.racing » Sun Sep 14, 2014 9:09 pm
if the shaft nut is spinning freely, that is your problem. check the threading.
sailaholic
Re: Tein rattles
Postby sailaholic » Sun Sep 14, 2014 10:54 pm
Bruce : http://mcablog.com/?p=409#more-409
Bottom adjuster for movement range. Spring preload for ride height.
There is a thread on here somewhere too started by magpie.
Re: Tein rattles
Postby bruce » Sun Sep 21, 2014 10:14 pm
Guess what. I was right. I got a breaker bar on the Tein spanner, loosened the bottom collar and wound the tube up for more height. Then locked down the bot collar.
I added 1cm in tube length which lead to the car going up around 4cm! I thought it would have been 1cm too? Will have to lower it back a little. I don't think it can settle (it's not a spring).
Users browsing this forum: No registered users and 231 guests
