NA8 rear brake pads (does it even matter what brand I use?)
gslender
Re: NA8 rear brake pads (does it even matter what brand I us
Postby gslender » Fri Aug 01, 2014 8:19 am
Oil sampling makes sense when the engine costs $15,000 but a used NB engine with low klms is $1500 fitted, so I'll just swap my oil after every track day and take my chances. Obviously if I was thinking of hitting 8000 rpm on a regular basis then my used NB would fly apart regardless of the oil and tests, so, as always it depends.
Sent from my iPad using Tapatalk HD
Postby Magpie » Fri Aug 01, 2014 12:09 pm
Oil sampling cost is around $35 a time.
gslender
Postby gslender » Fri Aug 01, 2014 2:53 pm
Magpie wrote:Oil sampling cost is around $35 a time.
Wow, including the removal, sending, advice and assessment on what it means... that's good value. Who are you using?
Postby Magpie » Fri Aug 01, 2014 3:19 pm
Users browsing this forum: No registered users and 236 guests
