Oversteer: FM Stage 2 V-Maxx kit + turbo
zossy1
Re: Oversteer: FM Stage 2 V-Maxx kit + turbo
Postby zossy1 » Sat Jul 14, 2012 7:14 am
zossy1 wrote:Beyond a certain point, it creates excessive tyre wear and contributes to turn-in understeer and power oversteer.
As I said, Dann.
5-10mm per side is WAY "beyond a certain point"!
gslender
Postby gslender » Sat Jul 14, 2012 9:17 am
Rear toe is normally used to manage straight line stability under power. Too much in either direction can result in oversteer. Preference should for a small amount of toe in.
G
Postby NitroDann » Sat Jul 14, 2012 12:16 pm
Well again that depends what you want the car to do.
Also, my car is running 5mm toe out a side in the back, its fine.
Anyways the point is that adding toe in will reduce the amount the car pivots, adding toe out will increase it.
Users browsing this forum: No registered users and 218 guests
