Get Rigid... MX-5 Suspension Braces
CJ5
Postby CJ5 » Mon Apr 27, 2009 6:09 am
yeh im still perplexed by the idea of removing all the car's bracing in an effort to improve performance
Postby Okibi » Mon Apr 27, 2009 9:33 am
Wun must be going for straight line speed :wink:
Szemen
Postby Szemen » Mon Apr 27, 2009 6:47 pm
CJ5 wrote:yeh im still perplexed by the idea of removing all the car's bracing in an effort to improve performance
Because in corner predictability, chassis stiffness, insurance, cornering performance and god knows what else all comes second place before weight :roll:
Okibi wrote:Wun must be going for straight line speed :wink:
But striaght line speed is less about weight, but power :wink:
marcusus
Postby marcusus » Mon Apr 27, 2009 7:44 pm
Szemen wrote:But striaght line speed is less about weight, but power :wink:
Actually, it's to do with both... power to weight is the all important factor, not just power.
Szemen
Postby Szemen » Mon Apr 27, 2009 7:53 pm
Weight has to do with the acceleration of the vehicle. It is ultimately the power, gearing as well as Cd that decides outright speed.
wun911
Postby wun911 » Mon Apr 27, 2009 8:29 pm
I'm not sure about safety I guess it would be like an NB8A in an accident, but not quite as safe as volvo??
I wish the under body bracing was like the ones in a lotus elise. Flat sheets of aluminum; stiff and helps reduce drag.
I get most of my lightweight ideas from this list:
http://www.dragstuff.com/techarticles/w ... ction.html
every ounce counts
Postby Okibi » Mon Apr 27, 2009 8:58 pm
So that's why you removed the rear seats :lol:
AB7
Postby AB7 » Mon Apr 27, 2009 9:17 pm
Wun, did you weigh the braces? cant be over 10kg all up.
Your soft top is 14KG, time to take them off!
Muzdaman
Postby Muzdaman » Tue Apr 28, 2009 9:02 am
I weighed a soft top and frame the other day. Including the rain rail bracket it was close to 19kg. This was an NA top, not sure how different an NB would be.
The hard top is 21kg.
wun911
Postby wun911 » Tue Apr 28, 2009 1:02 pm
NB will be heavier it has glass window in the soft top.
every ounce counts
AB7
Postby AB7 » Tue Apr 28, 2009 1:16 pm
wun911 wrote:NB will be heavier it has glass window in the soft top.
Even more reason for you to take them off...imagine - 20 KG :)
Matty
Postby Matty » Thu Apr 30, 2009 1:28 pm
The whole top assembly for the NB is lighter - because the frame is lighter.
GAGE
Postby GAGE » Wed May 13, 2009 3:45 pm
Is anyone here running one of these? Is it really as good as they claim and worth the $$$?
AB7 wrote:Welcome Ando, Thanks for sharing.
Btw those bars are standard on 2001 NB8B onwards, and you can install them also on to NB8A.
There are some other company that makes similar braces to yours (Autoexe, Cusco) but its quite expensive.
IMO prob the best chassis brace out-there is FM butterfly brace
http://www.flyinmiata.com/index.php?dep ... 20%2090-97
Ando
Postby Ando » Wed May 13, 2009 6:39 pm
It's a lot of $$$ and a lot of fresh holes to be drilled. 16 all up, I think?
The holes put me off and the results from the other bracing is very noticable and cheaper. The FM braces would be ideal for a lowered car though. The Ultra Racing ones do hang a bit, so clearance is reduced.
Ando
~ 1999 Twilight Blue NB8A ~
1として馬そしてライダー
greenMachine
Postby greenMachine » Wed May 13, 2009 9:10 pm
wun911 wrote:
Did 10AE have all this stuff becaus I know 10 AE is about 50-70 kg lighter than NB8B.
Really? ... Source? ... And where did they make this weight saving?
Sigh :roll:
:mrgreen:
Users browsing this forum: No registered users and 353 guests
