Are we hub centric?
Are we hub centric?
exactly.
look at it like this, if you dont have them, there is a slight risk of the wheel coming off/stud breaking.
if you have them, there is much less risk, with no downside apart from an extra 10grams of plastic.
it's like a vaccine, chances are you arent likely to catch some of the diseases they vaccinate against, but you may as well get it since then you dont need to worry at all.
- CoffeeBoss
- suntory
Are we hub centric?
My experience with this topic aligns with exactly what Matty and GreenComet are saying.
I have RPF1's with McGaurd lug nuts. Hubcentric rings are suggested, but not required. Like 949 Racing, Goodwin Racing also sell wheels for the MX5 which don't seat against the hub. Brian and Emilio both will tell you that hub centric rings are handy, but not needed. Spinning Wheel in Zetland have also confirmed this for me.
I've covered about 50'000kms with these wheels and lug nuts together on the car including plenty of track days. No issues.
- madboy
Are we hub centric?
does anyone know what OD size the 949 54.1's go to? it just says Toyota...I had two 54.1 to 73.1's put into my front wheels today, they seem to have sorted my nasty shaking at 110km/h, they could only find 2 in their tin of rings so i am looking for some more, any suggestions?
- Steampunk
- pcmx5
- Vehicle: ND - 2
Are we hub centric?
If your wheels have a taper and seat like the standard ones (or are complimentary if they are aftermarket)you are home and hosed.I find it difficult to believe that anyone could seriously suggest that a PLASTIC hub ring could be a load carrying part of the suspension, with the right nuts and taper it just sets up fitment!!!
Peter.
Peter.
- sliq
Are we hub centric?
http://www.miata.net/garage/hubcentric.html
Quote:
"If you have matched the bolt pattern, you could just bolt the wheel in place, but you would be relying on the lugs to center the wheel (a lug centric set-up)."
Re: Are we hub centric?
sorry to bring up an old thread.
ok, I'm going to be buying hub rings (I don't care what people's opinions on them are, I'm buying a set)
anyway, what's the MX5 stock bore? (for NB8A)
I measured the spare and got 54mm, just want to confirm this before buying.
also, my new wheels seem to have a step in the bore, it's 63mm at the back for about 15mm in, then a step to 62mm.
I presume then i'll need a 54/63 ring?
- Vehicle: Non MX-5
54.1mm
perfect.
exactly what I needed, thanks mate!
- toymx5
I'm so glad you you're getting the centering rings, I can't believe the uninformed and irresponsible comments buy some people on this forum. I have a brand new set of Momo wheels which have the exact same angled lug nuts as the factory wheels and each wheel has a massive sticker on them warning that it is dangerous to mount the wheels without the use of the proper centering ring.
Are you going on the GOR run next week, if so look forward to catching up again !
My little 'Toy' thinks she's actually a Ferrari !!
Unfortunately not Peter.
Scheduled to pick up a hardtop that weekend!
- Vehicle: Non MX-5
+1...toymx5 wrote:I'm so glad you you're getting the centering rings, I can't believe the uninformed and irresponsible comments buy some people on this forum.
- greenMachine
toymx5 wrote:
... I have a brand new set of Momo wheels which have the exact same angled lug nuts as the factory wheels and each wheel has a massive sticker on them warning that it is dangerous to mount the wheels without the use of the proper centering ring. ...
Peter, any chance of you posting a photo or scan of that sticker?
- toymx5
No probs, I will peel one of a wheel and take it to work tomorrow and scan it, I'll post it tomorrow night.
- Benny
My mate at Tempe Tyres would NEVER fit a new alloy wheel to a car without using a hub ring, and he has virtually every size available.
He reckons that you can certainly get away without using it, but he has found after many years of experience, that it is always safer to use them.
He reckons that they have had a number of out-of-balance problems with aftermarket wheels that were not fitted with the hub rings.
I do agree that a plastic ring can't take all the forces of a wheel going around a corner with a slick tyre on it, but it does help to make sure the wheel doesn't move around on the studs.
If one of the wheel nuts is just a little loose, you run the risk of the wheel being able to move around, and once it starts moving, then it will place huge stresses on the nuts.
