Lowering
- marcusus
Lowering
I didn't think Koni did a coilover? Bilstein do it though. When I was looking, I was considering PSS's and PSS9's. Benny swears by his PSS9's, and I don't doubt their effectiveness. However, the PSS9s are the top of the line Bilsteins and will set you back something ridiculous.
I think the PSS and Tein SS are on the same level, but I'm not sure what the price differences are (although I seem to recall them being in the same ball park, hence me thinking they're at about the same level), or indeed what the differences are between the SS and the PSS.
Lowering
as sliq stated earlier, i dont understand why you want to spend 2k to lower your car? by the sounds of it, you dont know what other abilities coilovers have other then lowering your ride height. you can get a matching shock and spring combo for less then 1k, (cheaper if you go 2nd hand, i picked up kyb's for $200 AND they also have knobs you can play with ) in my opinion, your wasting your money.
Lowering
If you don't spend enough then the new suspension that you are going to get is going to be worse than stock equipment and that is just pointless. If you're gonna lower your car, do it so that you actually improve performance or at least maintain. Its like buying cheap 17's, yeah they're bigger and might look better to some but they're not going to be as good as stockies.
You want to spend 2k to lower your car because thats how much it costs to do it properly, otherwise there is compromise, and thats fine if you're OK with it, but most people aren't.
- marcusus
Lowering
MXHEVN wrote:as sliq stated earlier, i dont understand why you want to spend 2k to lower your car? by the sounds of it, you dont know what other abilities coilovers have other then lowering your ride height. you can get a matching shock and spring combo for less then 1k, (cheaper if you go 2nd hand, i picked up kyb's for $200 AND they also have knobs you can play with ) in my opinion, your wasting your money.
Things work together in unison. When you buy separate products to perform a cohesive function, chances are they won't work as well. The "other abilities" you mention can only be pros for the car. Whereas if you do something on the cheap, things won't be matched, and you may end up making things worse. Of course the chances are reasonable that it won't be any worse, but if you're going to spend money, things should be improving, not maintaining the status quo. Otherwise what's the point of upgrading?
Besides, your name is only a re arrangement of the letters, so you should just get them to have the bragging rights of "yeah, I got shocks made with my name on them"
Lowering
marcusus wrote:MXHEVN wrote:as sliq stated earlier, i dont understand why you want to spend 2k to lower your car? by the sounds of it, you dont know what other abilities coilovers have other then lowering your ride height. you can get a matching shock and spring combo for less then 1k, (cheaper if you go 2nd hand, i picked up kyb's for $200 AND they also have knobs you can play with ) in my opinion, your wasting your money.
i'm not sure if you believe in reasearch or not? or maybe i have too much time on my hands to reasearch, basically tein SS are a package yeah? well basically with a matching shock and spring combo you want/need to figure out how stiff you want the spring rate, what spring rate the shock can handle to get it right.
Doing things cheap doesnt always mean its bad, whether its buying used or buying an item lower then another. With the logic of whats the point of upgrading, your going to need to spend ALOT of money in your sence to "Do it right" in your standards.
Tein SS arent an Entry coilover, and as i stated i dont believe that azntien needs such a coilover, he obviously doesnt know what other features it has other then height adjustment. If you want to stick to teins, why dont you just get the Tein basic? 949 racing sells them for $600, shipping give or take $200, installation give or take $200, $1000 and you have height adjustable coilovers installed, and if i didnt know what the SS did, i'd reasearch the hell out of it, even before i consider spending such a big amount of cash.
Lowering
Sasso wrote:If you don't spend enough then the new suspension that you are going to get is going to be worse than stock equipment and that is just pointless. If you're gonna lower your car, do it so that you actually improve performance or at least maintain. Its like buying cheap 17's, yeah they're bigger and might look better to some but they're not going to be as good as stockies.
mmm, i agree with not spending enough, but you dont need 2k to do it right. with the 17's that all depends on the owner, most people here think its suicide to do so, but some hate the small stockie look, i'm sure you have noticed that their isnt any fully sick people on this forum
i believe you dont need 2k to lower your car properly, JUST lowering your car and not have any other functions (maybe damping) you can get such a setup for under 1k. i couldnt care less if he wants to blow 2k on something he wont be using to its potential, its not my money. i'm just trying to give him some advice as ALL HE WANTS IS LOWERING.
ofcourse, when you put new shocks in your car they will feel so good. how many kms have your stock shocks done? if they had the same kms, i'm sure you would have such an OMG they are so good factor.
- philz
- Wheel guru
Lowering
That price is a rip.
I'm getting jap spec ones for $1300+ $200= $1500 all up.
for $2.3K installed you can get Tein FLEX + EDFC+ install.
I'm assuming you got quoted for Aussie Tein SS with uppermounts?
AZNTien does do autocross/motorkhana stuff, and the coilover suspension will benefit him.
I don't understand why you spend money on your Automatic mx-5, obviously you have your reasons, and so does Tien, he wants to do it right the first time, and not worry about it 1-2 years later, when his shocks go bust
Lowering
philz wrote:That price is a rip.
AZNTien does do autocross/motorkhana stuff, and the coilover suspension will benefit him.as sliq stated earlier, i dont understand why you want to spend 2k to lower your car? by the sounds of it, you dont know what other abilities coilovers have other then lowering your ride height. you can get a matching shock and spring combo for less then 1k, (cheaper if you go 2nd hand, i picked up kyb's for $200 AND they also have knobs you can play with ) in my opinion, your wasting your money.
you havent been around long enough to understand about my mx-5. i think he is just going with the crowd. either way i dont give a ƒü¢k anymore.
- AJ
Lowering
let's keep it civil boys, Tien was merely asking a question, he doesn't require you guys to have a pillow fight over your own preferences.
Tien is a young guy who's looking to more experienced people to give him solid advice about the best options for his car, if spending a bit extra means he gets what he wants plus added benefits, so be it.
XMX5 Rogues
- sliq
Lowering
that's weird, i haven't heard of anyone busting their shocks just because they've put in some aftermarket springs.. even with king springs.....
Users browsing this forum: No registered users and 128 guests
