RE001 review
- marcusus
So no one knows the answer to my previous question?
I suppose I should make an official comment on these since I've been running them for about 3 weeks.
Dry grip is pretty bloody good. Wet grip was alright, but I could still flick the rear out without much problem. They don't squeal nearly as much as my old Kuhmos do when I push it, and they seemed to do fairly well at the track when they warmed up (let's not mention my off at turn 3 at Wakefield on the very first lap ).
- Caffeine
rjastra2 wrote:Anyone after Adrenalins in 205/45R16 should give Jobsons in kensington a call. $197 fitted, $192 if you are NRMA member.
That's pretty much the standard bridgestone tyre centre price...
Caffeine wrote:rjastra2 wrote:Anyone after Adrenalins in 205/45R16 should give Jobsons in kensington a call. $197 fitted, $192 if you are NRMA member.
I rang a couple and they were quoting $225/230
- Boags
I was quoted $215 for 205/45/R16 RE001s in two different tyre shops today. $235 for Michillin PP2...
Boags
Boags
- Caffeine
marcusus wrote:So no one knows the answer to my question still about the rotation direction of the tyres?
They're not directional tyres, at least not in the size I have - 195/50r15. They just have an inside and an outside. Doesn't matter, they work brilliantly.
- Damo
I don't know about the particular tyres that you're talking about but certainly with some (including my RT615s) there is more tread on the inside. If you have some negative camber in your alignment you will be running on the inside shoulder when you aren't cornering too hard. If it's wet you won't be able to corner too hard so there's no reason to have much tread on the outside shoulder.
So, basically, different parts of the tyre are going to be used to different extents under different weather conditions. Actually, I suppose even if you don't have much neg. camber you'll still run on the outside shoulder side more when there's more grip (ie. dry weather).
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
- marcusus
manga_blue wrote:They're not directional tyres, at least not in the size I have - 195/50r15. They just have an inside and an outside. Doesn't matter, they work brilliantly.
That's essentially the confirmation I'm after. Thanks for that
- TieNN89
marcusus wrote:manga_blue wrote:They're not directional tyres, at least not in the size I have - 195/50r15. They just have an inside and an outside. Doesn't matter, they work brilliantly.
LOL I got mine today and was at the panel shop looking at the tires wondering if its directional or not
and wow the tires must weigh a lot
my rims were light as till the tires came on they felt like they weighed more than 2 of my rims
How much are people paying for there RE001 in 15" 195 / 50
I got mine for $120 fitted onto new rims not onto the car
AZNTieN wrote:marcusus wrote:manga_blue wrote:They're not directional tyres, at least not in the size I have - 195/50r15. They just have an inside and an outside. Doesn't matter, they work brilliantly.
There are people here obsessive enough to carry electronic scales with them when they go tyre shopping.
Ahem ... Bridgestone Adrenalin RE001 195/50R15: 8.55Kg.
- TieNN89
manga_blue wrote:AZNTieN wrote:marcusus wrote:manga_blue wrote:They're not directional tyres, at least not in the size I have - 195/50r15. They just have an inside and an outside. Doesn't matter, they work brilliantly.
lol carry scales with them wow
8.55kg
Users browsing this forum: Bing [Bot] and 19 guests
