Wheel and Suspension Facts And Figures
mazmad
Re: Wheel and Suspension Facts And Figures
Postby mazmad » Sat Feb 23, 2013 6:52 am
Dale good find. How do you fit it, cable ties?
I will post this elsewhere too but what I don't get is the flammability of the foam -rubber is flammable, is this treated foam?
Postby 93_Clubman » Sat Feb 23, 2013 1:17 pm
Used cable ties here. Don't know if it's treated, however given it's being sold by Revolution Race Gear I'd expect it to be suitable for track purposes, but haven't confirmed this.
mazmad
Postby mazmad » Sat Feb 23, 2013 5:47 pm
erskimo
Postby erskimo » Tue Jan 20, 2015 2:32 pm
Able flex, boys and girls, it a foam product that comes in different sizes 100mm x 10mm x 6m, 150mm x 10mm x 25m (if I remember correctly) its got a 'sticky back on one side its used in construction. It may help
baaaRINGGG dadinggg ding ding
Postby hks_kansei » Tue Jan 20, 2015 2:52 pm
I'd be wary of using pipe lagging over proepr rollbar padding.
Rollbar padding is quite firm in order to absorb the impact from a decent speed.
Pipe lagging (all the stuff I've seen anyway) seems to be a lot softer, and won't protect you much in an accident.
Basically, if you can compress the foam easily with your hand, you'll also compress it even easier with your head at 60+kph.
rascal
Postby rascal » Tue Jan 20, 2015 3:48 pm
hks_kansei wrote:I'd be wary of using pipe lagging over proepr rollbar padding.
+1 on this..
The FIA stuff is that stiff that it makes it difficult to fit into the car, and a pain to fit around corners. (I ended up having to cut into triangles to fit around the cage bends)
The upside of that is that it absorbs the forces more appropriately when a helmet slams into it..
The soft foam mentioned above, may be easy to fit but wouldnt be much better than the bare bar with respect to cushioning an impact..
Postby Magpie » Fri Jan 23, 2015 7:53 am
Not at the moment FIA approved but if it is good enough for a motorcycle helmet and motorcycle race suits http://www.d3o.com/d3o_products/plain-and-mesh-sheet/
MattR
Postby MattR » Fri Jan 23, 2015 7:29 pm
But unfortunately not acceptable for use in CAMS racing events as it is not FIA approved.
It may be fine for sprints but that would be up to the scrutineers at that event.
Custardtart
Postby Custardtart » Tue Oct 30, 2018 6:31 pm
Having hit my head on both I vote for the proper stuff. Can also save your helmet at relatively low speed impacts
NC1 - 2.5 opposite lock device
Lakeside 62.3
