Toyo T1-Rs
- bigdog
- King of the kennel
- Mr Starlet
- bigdog
Was just about to ask the same question! As you know, I just had mine fitted. I took them through the paces through some twisty backroads and found them very squishy on the sidewalls at high speed through corners.....even a little scary! Have them fitted to standard 16\" NB8B rims (205/45/16). Tyre guy recommended 36PSi front/rear. I tried 38PSI for the return trip and they seemed a little better, but still dont feel as good as my old warn out Turanzas!
Any suggestions!! Maybe have them too hard! What are people running at the track??
Thanks
Thanks
- bigdog
- Craig
- Vehicle: Non MX-5
- Charlie Brown
Just put a set of T1-Rs on the NC.
I procrastinated about them or the Michelin PP2s. There was absolutely no difference in price - $250 a corner. In the end I decided to go the Toyos hoping they would last better with the odd track day that I do. Mind you the PP1s lasted 30K plus 6 track days so they were pretty good.
After just a week on them I’ve found that they are softer in ride than the OEM Michelin PP1s. They are just as quite, but and it is a big BUT, they seem sloppy.
I know that people will say wait till the mould release is worn off but this isn’t slipperiness it’s slow reaction to steering inputs.
I’m running 32psi, 10% higher than the recommended pressure, so if I go higher I will be trading off grip for response.
I’ve yet to really try out the grip so I’ll reserve my final opinion till after I really break then in at Wakefield in March.
Fingers crossed that they hang on better than the Michelins otherwise it’s an expensive mistake.
- Marty
CB, I found the same thing when I first got my tyres. They weren't overly slippery to start with but the were very squishy with their response. This seems to have gone away to a major extent with a few good runs on them.
I have taken some good fun runs on them but I look forward to giving them an absolute thrashing somewhere to see it they firm up even more.
BTW I'm running 36psi cold. Haven't played around with pressures yet but when I'm feeling a bit less lazy I might get out and do it.
Silver SP 153.7kw atw for $2
Mine seem to be a bit better, I now have them at 34PSI instead of the recommended 36PSI. But I havent had them up at high speed again yet.
Craig - had a look at the tyres and I cant find the code you were talking about...all I found was a 'made in japan'.....the Dot rating DOTCXVN, code PXT1R and the following which I have no idea of....0225321 and 0225510-S...
Fleery.
Fleery.
- Craig
- Vehicle: Non MX-5
Made in Japan is the important one, means they aren't the crap imports from China. The date is a 4 digit number on the tyres sidewall, from memory it flat and oval where the numbers are, not hugely important unless they were old stock but I doubt that as most tyre place ran out as Toyo didn't order enough for the anticipated demand last year!
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds! ***
Users browsing this forum: No registered users and 162 guests
