New wheel allingment Straight talk suspension
bigdog
King of the kennel
Postby bigdog » Thu May 04, 2006 10:50 pm
Feels good! Havent had a real go at corner yet - car full of computers and stuff today :( Will find out over the weekend.... 8) Good luck at Wakefield, looking forward to the video!
rodent
강남 스타일
Postby rodent » Fri May 05, 2006 12:40 am
Yeah I finally got my suspension install booked for the Tuesday after next. Can't wait!
Gotta find some nice wheels now... :mrgreen:
jonno.
StanTheMan
Postby StanTheMan » Sat Jun 03, 2006 3:34 pm
Ok after driving the car for a little while. I've decided it needs improving.
currently the stats are
front
camber 2.25 deg
toe 0
max cast.
rear
camber 2.5 deg
toe -1.5mm
the turn in is very lathargic. needs a fair bit more aggression.
how is toe out going to affect tyre wear?
I also have a NB8A fron sway....not sure what size they are but it give natural understear as the rear is standard NA6
CT sugessted 1-1.5mm out at the front.
any more creative critisim?
should i also then change the toe at the rear?
JBT
Postby JBT » Sat Jun 03, 2006 6:36 pm
Any good and realtively cheap place to get car alligned? I paid $77 last time to get it done, front and rear.
That's about the going rate for a 4 wheel alignment. The main thing is to make sure you take it some place where you are confident that they actually regularly calibrate their equipment as well as accurately set the alignment.
Charlie Brown
Postby Charlie Brown » Mon Jun 05, 2006 6:11 pm
Slugoid, if you have lost the turn-in response you strive for then you will need to go for a touch front toe out but that together with your proposed 2 degrees negative camber will make the car tramline and darty under brakes.
Unless you run semi track tyres like Stan or have the car lowered, I’d stay away from that much negative camber. If you are running street tyres then your current settings seem fine.
I think previously you had so much rear toe-in that the car was really dragging its arse around and therefore the front felt more responsive.
Cost wise I’m paying $88 at Spinning Wheel. You tell Stu what you want and he dials it in. If you’re not happy with the results he’ll redo them for free until you get what you want (within reason).
