My New Tein SS!!!
- Brad
Ahhh, I see. Full hard is easy to tell as it's a definite end to the movement, but you're right, going through to the other end get's vauge. I had it originally at 14/13 f/r clicks from full hard because I thought that was the mid point, so that would make it only 2/3 from full soft, no wonder it felt under-dampened.
I've been very carfull not to turn very hard at all. I'll make sure I count back from full hard from now on.
Thanks for the help Bab's, BTW what do you run them at, dampening and height?
- godfather of saké
Brad wrote:Ahhh, I see. Full hard is easy to tell as it's a definite end to the movement, but you're right, going through to the other end get's vauge. I had it originally at 14/13 f/r clicks from full hard because I thought that was the mid point, so that would make it only 2/3 from full soft, no wonder it felt under-dampened.
Yeah the instructions say not to go past full-soft so you should be careful.
From memory, I adjusted it to 30mm from the bottom of the threaded bit to the bottom of the lower collar and that is about 325mm all round. Damping wise, I swap between 2 settings for road, 8/8 and 15/15 for bumpy roads.
2/5 seems to work well for fast road/track, but I find that it's too firm up front unless you're really stropping along and braking hard into corners, etc. If I leave it on 2/5 and just coast into a tight corner the front end gets a little washy, so I find the softer 8/8 setting is more fluid for 6-tenths driving.
Babalouie wrote:Mine took a few hundred kays to really settle, so you'l probably find that they will settle at about 320mm each corner.
i'm still puzzled why mine hasn't dropped much after a few months and few thousand kays............
- godfather of saké
Philip Lee wrote:Babalouie wrote:Mine took a few hundred kays to really settle, so you'l probably find that they will settle at about 320mm each corner.
You're probably not as fat as me
Babalouie wrote:You're probably not as fat as me
- Brad
Had some clarification on the adjustment of these...
Hi Brad,
If you adjust the mechanism all the way in [clockwise ] that is the hardest position . Back it off 16 clicks and that is softest .
The extra clicks you get is the result of free play in the adjusting mechanism. Not a problem, driving or what ever can not damage it. Because after 16 clicks there is no further change.
Let me know if you have anymore Queries
Regards
Ryan Scudamore-Smith
Sales Support Co-ordinator
Fulcrum Suspension
Hi Brad,
Regards
Fulcrum Suspension
- godfather of saké
Brad wrote:Had some clarification on the adjustment of these...
Hi Brad,
Regards
Fulcrum Suspension
Good to know!
- pcmx5
- Vehicle: ND - 2
Hi Brad,
Regards
Fulcrum Suspension
Interesting that the instruction book says exactly the opposite!!!!!
Something like;Caution do not go past 16 clicks- This will damage the shock.
Peter.
- jules
- Guitar Hero
- Brad
Did a few runs up Mt Cootha last night. Started at 12/12 which was very nice, great turn in and excellent bump absorption with MUCH more grip. Once at the top I set them to 16/14 and was just blown away. So positive, so predictable, so much grip and still a less harsh ride than the Bilsteins. Drove then all the way out to Rochdale on this setting and they were actually more comfortable over roads I know well, though still very firm. Settled on 10/8 which seems so be a good balance for day-to-day use.
Brad wrote:So positive, so predictable, so much grip and still a less harsh ride than the Bilsteins. Drove then all the way out to Rochdale on this setting and they were actually more comfortable over roads I know well, though still very firm.
Yeap, have to agree with you on the grip and ride.....thats why I love my Tein Flex.
J
- Brad
- Brad
Juffa wrote:Brad wrote:So positive, so predictable, so much grip and still a less harsh ride than the Bilsteins. Drove then all the way out to Rochdale on this setting and they were actually more comfortable over roads I know well, though still very firm.
J
Juffa, what are your thoughts on the bushes you use?
- JBT
jules wrote:JBT,
Not happy with your Koni's???
Jules
Still very happy although I sometimes feel that the Kings may be a bit harsh on sharp bumps. The ride height adjustability of the Teins appeals to me though. I also hear that Eibach springs are not as harsh as the Kings and combine well with the Konis. How do the Teins behave harshness wise compared to Kings? Also what's the 12/12, 10/8 about?
