Front 300mm Brake conversion
- NitroDann
Re: Front 300mm Brake conversion
Good post.
For what its worth
The 300mm rotors are from a Renault Grand Scenic
The Calipers Subaru 4 pot WRX.
So, by the time you buy
Rotors
Caliper mounting brackets
Calipers
Pads
Brake hoses,the MX5 one are too short
You will have spent around $900
Steven
Rotors
Calipers
Pads
Steven
- Vehicle: Non MX-5
61mm centre hole on rotor? what did they do to fix this issue?
- greenMachine
I thought I had posted a followup to my earlier post ...
Long story short, it might be cheap (?) but it is not light, an important consideration for me. I am not interested in pursuing this option, but if I were my next question would be about comparative wheel cylinder volumes and implications for m/c sizing.
I have just ordered Carbotech pads for the SE, so I will see how they stand up to heavy use before investigating alternatives.
- Vehicle: Non MX-5
I also think this combo isn't matched correctly. The caliper came off a car with 277 dia rotors. Bumping that up to 300mm is a far wack and look like a lot of pad doesn't make contact.
It be nice to see this setup with NB 270mm rotors.
