Think your weights are back to front for the first two lines. The first pic (13.3kg) looks to be a 6UL rim, the second (13.4kg) looks like a S1 rim
205/50/15 Wheel widths
Re: 205/50/15 Wheel widths
Oooops, you are correct, thanks!rascal wrote: Think your weights are back to front for the first two lines. The first pic (13.3kg) looks to be a 6UL rim, the second (13.4kg) looks like a S1 rim
Of possible interest:
Magpie almost wrote "205/50/15 x 7.0" (AD08R's) 13.4kg (Advanti Racing Storm S1's)"
I write: 205/50/15 x 7.0" (A050s) 13.8kg (Advanti Racing Storm S1s)...with 3mm tread depth remaining.
StillIC wrote:Of possible interest:
Stiffer sidewalls are heavier?
StillIC wrote:I write: 205/50/15 x 7.0" (A050s) 13.8kg (Advanti Racing Storm S1s)...with 3mm tread depth remaining.
Interesting! The AD08R's on the 8" probably have about 3mm of tread left as well.
Managed to get under the 60 secs at QR on the sprint today using the AR-1's on 6.5" rims.
- rossint
205/50/15 NT-01 (8.31" published tread width) on 15x9 6UL 13.6kg.
The other thing that's worth looking at is braking performance with the different wheel widths, have you looked at that data Magpie?
