davekmoore wrote:Took your time there Dann!
How come, now you're a sponsor, your sig doesn't mention your magic tricks? Or do you just rely on certain people dropping your name from time to time?
Which magic tricks though?
Magpie wrote:Using some heat paint on the discs and temperature strips on the calipers will help you track where the issue is.
Steampunk wrote:What brake fluid are you using?
How often do you flush/replace?
greenMachine wrote:Dave, it looks to me like there are two possibilities at the root of your problem.
One is brake fade. As Magpie suggested the best way of testing for this is to put some of those heat sensitive strips/paint on your callipers/disks (read the instructions) and then do a track test. They will change colour according to the max temperature reached. If that exceeds the temperature range of your current pads, you now know what temperature range you need in your new pads.
greenMachine wrote:(I am assuming you bleed the brakes regularly - like before every event, and perhaps every session - and use high temperature racing fluid.)
greenMachine wrote:Pad knock-off shows in a long(er) pedal, as the pads are forced back to the disk from where they have been pushed, but after that movement they should behave as intended - this might require a quick pump of the pedal depending on how far the pads have to move.
greenMachine wrote:The other is lack of brake boost. I don't know what demon tweaks Dann may have on your engine, but I do know of one turbo MX5 racecar that required a vacuum pump for the brake booster - and it transformed the car (as it did mine).
greenMachine wrote:I assume (again) that you are datalogging engine parameters, including boost. Have a look at the boost trace, and see how much time it spends in negative territory (ie, vacuum in the inlet manifold rather than boost, which means vacuum in your brake booster) during a track session. You might also want to check that the one-way valve in the vacuum line between the booster and the manifold is working correctly, allowing the manifold to suck air out of the booster but not allowing air to flow back towards the booster. You could also put a pressure sensor on your brake line(s), and datalog that to see what your line pressures are. By looking at line pressures, braking 'g', and boost/vacuum pressure, you should be able to confirm/discount this as a/the cause/contributor to your problem.
davekmoore wrote:Temp range of current pads seems to be above the range of the strips/paint.
davekmoore wrote:Not presently - so possibly boiling fluid during a long braking event? What fluid do you recommend?
davekmoore wrote:greenMachine wrote:The other is lack of brake boost. I don't know what demon tweaks Dann may have on your engine, but I do know of one turbo MX5 racecar that required a vacuum pump for the brake booster - and it transformed the car (as it did mine).
Dann might chip in with a comment here?greenMachine wrote:I assume (again) that you are datalogging engine parameters, including boost. Have a look at the boost trace, and see how much time it spends in negative territory (ie, vacuum in the inlet manifold rather than boost, which means vacuum in your brake booster) during a track session. You might also want to check that the one-way valve in the vacuum line between the booster and the manifold is working correctly, allowing the manifold to suck air out of the booster but not allowing air to flow back towards the booster. You could also put a pressure sensor on your brake line(s), and datalog that to see what your line pressures are. By looking at line pressures, braking 'g', and boost/vacuum pressure, you should be able to confirm/discount this as a/the cause/contributor to your problem.
No datalogging going on here. It all sounds too clever for me.
Will have the one-way valve checked.
Users browsing this forum: No registered users and 194 guests
