Grinding/knocking noise while cornering right
speed
Re: Grinding/knocking noise while cornering right
Postby speed » Wed Dec 09, 2015 12:39 pm
Had a similar issue. Would happen mostly when turning right. I also suspected back left hub or a LCA bush. Turned out to be muffler hitting a bolt on the heat shield!
speed
Postby speed » Wed Dec 09, 2015 12:44 pm
StanTheMan wrote:another member tried to do an internal engine clean. Got compression lock up. Bent all his rods.
What did he put in the engine to do that?
Just so I never do it :)
Postby manga_blue » Wed Dec 09, 2015 3:07 pm
Water.
Postby manga_blue » Wed Dec 09, 2015 4:44 pm
Actually it's worth reliving the whole UA water thread.
viewtopic.php?f=29&t=26318
Great guy, sadly missed here.
Steampunk
Postby Steampunk » Wed Dec 09, 2015 5:50 pm
So glad his memory is kept alive :beer: :)
Coincidentally "Max" turned up to our Mt Nebo run just last Friday after a too-long (more than 2 years) absence from current owner.
StanTheMan
Postby StanTheMan » Wed Dec 09, 2015 6:20 pm
tbro wrote:
StanTheMan wrote:Although not quite as funny another member tried to do an internal engine clean. Got compression lock up. Bent 2 of his rods. He was pretty shitty. Eventually saw the funny side. did an engine swap on a Gold Coast Dodgy day.
BUT there was a good side to it.
RIP UA
Terry
Boagsy won that award if I remember correctly. Is he still around?
