Press out old bushes -SYD
Re: Press out old bushes -SYD
Mark, you can get a press from Super Cheap for $160 at the moment.
- Dweezle
Thanks Bryan, i will look into that.
Do not really have room to keep a press though
Huge THANKS TO TBRO!!
Hopefully you see this.
I was just informed you called me yesterday i really appreciate your help mate.
I do not have a number for you and you PMs turned off.
Really appreciate it.
YOU ROCK
Pass me some bank Details and i will forward you some cash for the postage and i will get it straight back to you.
Again i really appreciate it.
Thanks
-Mark
YOU ROCK
Thanks
-Mark
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- Pamex
Use a vice and various sized sockets. You don't need special tools.
If you don't have a vice, they're cheap, and it's a worthwhile investment. Spend the money there instead.
the poster indicated he did not want to do it for the usual reasons like equipment and time. Pedders do it day in day out and have the equipment and the expertise. This work can probably be done same day.
- Vehicle: Non MX-5
or you can just put then in the freezer and not aplly any chemicals to them.ralt wrote:Hi.
When putting in rubber bushes not the ones with metal jacket immerse them in metho for 20 minutes shrinks the rubber when they dry are their original dimensions.
- Vehicle: Non MX-5
^this^Pamex wrote:Use a vice and various sized sockets. You don't need special tools.
- Vehicle: Non MX-5
you shouldn't really need a hammer. if you heat the oem bushes enough, they will start to burn and eventually just burn themselves out. don't breathe in the black smoke.StanTheMan wrote:Dweezle wrote:Thanks Stan.
When you heated them out did it leave a mess inside the control arm??
No mess it was really just so it is easier to cut the head off & push the bushes out easier.
- Dweezle
PACKAGE ARRIVED FROM TBRO!!
Seriously THANKYOU.
Really appreciate going to such an effort for me mate.
Along with the directions, this looks like it will do the trick well.
I also found these in the garage.
They have been hidden away for a year or so.
So now just to wait for a time when i have a couple of weeks between events to get started.
I will do the Rear first as that looks a fair bit easier to get to the Control Arms and then tackle the front.
Seriously THANKYOU.
Jeremy Clarkson
Jeremy Clarkson
- two40
Looks very civilised compared to the pitch forks and torches you see people using...
Good luck Dweezle.
Good luck Dweezle.
Users browsing this forum: No registered users and 46 guests
