Q about Yellow speed Coilivers
angusis2fast4u
Re: Q about Yellow speed Coilivers
Postby angusis2fast4u » Fri Nov 07, 2014 11:00 pm
okay so spring rates are 8kg Front and 6kg Rear Still seems weird to me. Spring is Captive at full droop as well
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
sailaholic
Postby sailaholic » Sat Nov 08, 2014 7:12 am
Margpie has BCs, ER in the rear and br?? In the front for memory.
Personally I think yellow speeds are crap and you'll chase your tail hoping to get something decent. I'd be selling them for some bcs or mca (unless you can afford MCA reds, in that case buy reds)
Having said that... The behaviour you mentioned does seem a bit odd. Have you tried talking to Mania?
Postby Magpie » Sat Nov 08, 2014 7:43 am
Sailaholic is correct on my setup, however running 9/6 spring rates. MCA's being looked at to replace current setup. Once I get my unsprung weight I'll decide on springs/shocks.
Again I agee with Sailaholic something seems wrong.
angusis2fast4u
Postby angusis2fast4u » Mon Nov 10, 2014 6:40 am
I might give mania a call today and see what they suggest, it should be faulty parts as they are new but you never know haha
~Angus
2001 Silver NB8B
angusis2fast4u
Postby angusis2fast4u » Tue Nov 11, 2014 6:32 pm
Roadrunner wrote:That doesn't seem right at all.
Iv got yellowspeeds in an nb and at the factory setting (6 clicks from softest I think) the car pushes down a little but springs straight back up and stops. No bouncing.
Mx5Mania are the dealer for them, maybe stop by and show them.
The original owner may have tried to adjust the height and adjusted/unscrewed the wrong thing??
I just rung them and they said they've never dealt with this issue before
The springs are 7/6kg - But being this soft still wouldn't be normal would it?
sailaholic wrote:Margpie has BCs, ER in the rear and br?? In the front for memory.
Why would you say to go Reds in a Daily? Curious on this
~Angus
2001 Silver NB8B
sailaholic
Postby sailaholic » Tue Nov 11, 2014 9:03 pm
go the best your budget allows.
Reds aren't a "track" coil over like yellow speed vs yellow speed pro, they are just better then blues.
Spring rate is the same, the extra money is all in the valving, oil, and having them dyno tested prior to delivery.
I'd rate my reds are probably the best thing i've done to the car. I had some buyers uncertainty at first, but after fitting and driving them, and feeling them outperform a set of Ohline, i'd definitely go reds again.
angusis2fast4u
Postby angusis2fast4u » Tue Nov 11, 2014 10:46 pm
sailaholic wrote:go the best your budget allows.
Have you dríven an MX5 with Blues installed? are you able to compare if the extra 1k is worth the difference? also have you dríven an MX5 with BC's in it? (Just asking as my old MX5 had BC's and would like to hear a opinion on that difference) After reading up on their website I now understand they aren't as track orientated as I first thought so I will definitely consider them now.
~Angus
2001 Silver NB8B
sailaholic
Postby sailaholic » Tue Nov 11, 2014 11:25 pm
No haven't dríven blues.
I've dríven Magpies car on bcs but not long enough to make a real opinion. Have a feeling I've dríven something else with Bcs but can't remember.
Have dríven ksport, ohlins, avo yellow speed and kings / konis.
Plohl has dríven my car (almost as much as me) and may have dríven BCs in someone else's car.
angusis2fast4u
Postby angusis2fast4u » Wed Nov 12, 2014 4:46 pm
Alright ending this topic by saying today I have come to a conclusion on the issue..
So as I was purchasing this car I was told they were yellow speed coilovers, and they look like yellow speeds (yellow body and black springs) BUT they are in fact a yellow speed imitation off of eBay out of Hong Kong.
Thanks for the help on this topic guys but there is no saving this set of coilovers from the tip..
~Angus
2001 Silver NB8B
sailaholic
Postby sailaholic » Wed Nov 12, 2014 5:26 pm
Some one will still pay money for them just to get low. $200 bucks is better then nothing.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Nov 12, 2014 10:52 pm
Glad you got that sorted out. :shock:
Iv been very happy with my (genuine) yellowspeeds
MeepMeep
Roadrunner
coyotes after you
Postby Roadrunner » Wed Nov 12, 2014 10:53 pm
Did you inform Mania that they are knockoffs? They may be interested to know.
MeepMeep
Postby hks_kansei » Wed Nov 12, 2014 11:36 pm
Roadrunner wrote:Did you inform Mania that they are knockoffs? They may be interested to know.
He didn't really say they were yellowspeeds, more that they were yellow, and the previous owner said they were yellowspeeds.
Either way, sounds like a good thing, yellowspeed, ebayspeed, or whatever, there are much better setups out there.
angusis2fast4u
Postby angusis2fast4u » Wed Nov 12, 2014 11:37 pm
Yeah, (I forgot who I spoke too) but they were extremely helpful in finding out all the info, so I will definitely be in contact with them in the future if I need anything from them [THUMBS UP SIGN]
~Angus
2001 Silver NB8B
