Handbrake warning light staying on- causes
Re: Handbrake warning light staying on- causes
Trust me , I will be checking all of the above re leaks!! Don't want to lose my stoppers
- Vehicle: Non MX-5
if you track the car, most likely out the res cap. i lose about 25% of the res per track day.
but even if you have new lines, check the fittings/ends also, as i've need a few not screwed up right also.
some cars just eat the stuff, and a leak can never be found. but if you are loosing brake fluid at a quick rate, then you'll find the leak.
It is just track car only.
res cap being the brake reservoir fluid cap? It leaks from there? Will check that, double thanks. Good tip >= take spare fluid!!
got the same issue hear.. though mine is on very dim.. when i pull the handbrake up it comes on bright the returns to being dim when i put the handbrake off...
not fluid.. done a full change and reservoir is full.. will just connectors as per Dann this weekend
thanks
thanks
Users browsing this forum: No registered users and 36 guests
