16x7 +25 - Will they rub?
Kikuchi
Re: 16x7 +25 - Will they rub?
Postby Kikuchi » Thu Jun 14, 2012 5:12 pm
i think you might have been quoting me for the 16x8 +20, 205/45, dumped, wheels rubbing.
I've since got a wheel alignment, 1.5deg neg at the front. No more scrubbing. The reason the left side was scrubbing was that it had 0.5deg positive camber, while the right side had 0.5deg neg camber.
When I have more free time, I will be lowering again to see how far I can push it as well has getting 5 or 10mm spacers.
Willstar
Postby Willstar » Thu Jun 14, 2012 5:44 pm
Haha, are you entering into a limbo contest?
How low Can you go¿
Yeah, your car is responsible for the hole in my pocket.
I want it! :lol:
Postby Jeo » Thu Jun 14, 2012 8:15 pm
What's your current height from centre of hub to top of guard? I know you said ~30mm lower than stock, but that doesn't really tell the whole story. Gernally I'd say that assuming you're not stupid low, you should be right, maybe needs a roll.
Also, fenders are American.
Willstar
Postby Willstar » Thu Jun 14, 2012 8:18 pm
Stratocasters?
Guards?
PaulF
Postby PaulF » Thu Jun 14, 2012 11:57 pm
I have a fender.
Sorry, I'm contributing to the "useless thread is useless" theme here.
Hjt
Postby Hjt » Fri Jun 15, 2012 1:47 am
Related note: if you ever decide to run spacers that slip on please replace your wheel studs with extended studs prior. There isn't sufficient clearance, even with a 5mm.
You would be surprised what you can fit under stock guards with the "guards" rolled.
MadMikey
Postby MadMikey » Fri Jun 15, 2012 2:36 am
and1 wrote:16x7, +38 with 30mm rear spacers and 25mm front spacers. Effectively making +13 at the front and +8 rear.
Guards are not rolled. Lowered on King Springs on standard SE shocks. No scrubbing whatsoever.
Tyres are Hankook Ventus RS-2s in 205/45/R16.
And I'm going to sell this setup soon.
So to answer your question, should fit no probs
Hey And1, shoot a pm to me before you list them for sale, I'll be very interested.
Mike
Willstar
Postby Willstar » Fri Jun 15, 2012 9:16 am
Hjt wrote:Related note: if you ever decide to run spacers that slip on please replace your wheel studs with extended studs prior. There isn't sufficient clearance, even with a 5mm.
Thanks Hjt, I'll be avoiding spacers all together. I like being insured :P
Looks like i'll be rolling my fenders with PaulFs Fender. I bet is plays 'smoke on the water' and smells like teen spirit a treat!
PaulF wrote:Sorry, I'm contributing to the "useless thread is useless" theme here.
I like it! I think there should be a whole section on this forum for "useless thread is useless" threads.
Goes to show bruce, don't be too serious. Its a discussion board after all, not parliament! Too much seriousness gives you cancer!
Kikuchi
Postby Kikuchi » Sat Jun 16, 2012 2:44 am
Yup, definitely getting extended studs. Depending on the spacers I get I'll probably get some open ended nuts as well to suit (or rather will need open ended nuts).
The mx is a show car as well as track toy, current shoes and the future plans for spacers plus more low is for show car, I'll be getting some 15x8 6ul's +36 (i think they were 36) for tracking and motorkhana later. lets me leave semi slicks on the track wheel instead of swapping tyres each time.
