Loctite red thread lock after suspension swap???
Willstar
Re: Loctite red thread lock after suspension swap???
Postby Willstar » Tue Oct 25, 2011 9:07 am
K, i had my mechanic look over it last night, who was happy that all was reassembled correctly.
I know my wheels wont fall off now! :lol:
That torque figure would still be handy though :wink:
Postby hks_kansei » Tue Oct 25, 2011 1:52 pm
Long bolt is 100nm if I remember correctly.
And agree 100% with others, buy a torque wrench, even a cheap Repco one should do, I think mine was $50 and according to the spec sheet is accurate to within 5nm or something, which for most things is within the factory specs.
I found the Torque spec on teh Miata net garage, listed in one of the suspension how-to guides if I remember.
Postby 93_Clubman » Tue Oct 25, 2011 1:58 pm
Willstar wrote:Ill have to look further into the manual, but i havent seen it as yet.
This link doesnt tell you the torque for the long upper control arm to body bolt. The long 30cm one.
Rod's & Hayne's manuals both state 87 - 101 Ft-lbs, or 118 - 137 Nm.
Willstar
Postby Willstar » Tue Oct 25, 2011 2:25 pm
:?: Where in the Haynes manual:?:
Postby 93_Clubman » Tue Oct 25, 2011 3:50 pm
Haynes Page 10-1 under Torque Specs for Front Suspension.
Willstar
Postby Willstar » Tue Oct 25, 2011 3:59 pm
Ta :wink:
Postby hks_kansei » Tue Oct 25, 2011 6:24 pm
Oops, I must have been thinking 100ft/lbs instead of Newtons.
timk
Postby timk » Tue Oct 25, 2011 8:53 pm
I use Loctite blue on all that stuff just to be safe! 8)
