snshami wrote:Anyone know of someone selling a good set of 14" RE001s
Your local Bridgestone store, second hand tyres might provide you with the same problems that you have now.
Greg.
ZR wrote:I'm after some recommendation for tyres for my NA8 wheels.
I after something grippy for streets and spirited drives (I dont go to tracks)
Is RE001 still a good tyres for this or has anyone else got any suggestions?
Guran wrote:Camber on stock NA? You can definitely get at least 1 degree front and 2 degrees rear with stock suspension and bushes. If your aligner doesn't know how, take it to a better aligner! Most tyre places will only adjust toe. I have been using Pedders - they're a bit more expensive but suspension is their specialty and you get want you pay for.
ZR wrote:Thanks guys
RE001 and PP2 it is
manga_blue wrote:Just picked up a new set of RE001s for the other car from Tyrepower. Made in Japan in Oct 2010.
I'm beginning to develop a theory about why people have such mixed opinions with these tyres. On my car they must be kept soft. Grip starts to fall off rapidly when I go past 28psi. 32psi seems to be about the absolute limit of driveability for public roads (though track pressures can be higher if you get them hot and sticky). Above 32psi they're pretty average in the dry and scary in the wet. In other words they work best at placarded rates of 26-28psi.
From an earlier topic here about what tyre pressures do you run there seems to be a trend that those who liked higher tyre pressures had bad experiences with RE001s. Maybe they just put too much air in them???
Users browsing this forum: No registered users and 121 guests
