What do Swaybar Endlinks do?
Postby 93_Clubman » Sun Aug 23, 2009 11:36 am
mhj wrote:my car is lowered with standard shockies....and i have broken an link without being mean to the car...from these posts that suggests that they are loaded inncorrectly?!?!...so should i get the beefed up or adjustable thingies??
Do you have standard sway bars front & rear? If not, what thickness are they?
mhj
Vehicle: NB8A - Supercharged
Postby mhj » Sun Aug 23, 2009 4:38 pm
heavier sways front and rear...dont know the number but they are non adjustable signature sways from mx5 mania
mhj
Postby 93_Clubman » Sun Aug 23, 2009 5:54 pm
the mania website doesn't have any numbers either, but unless you specified really thick swaybars i would expect that you've got 24mm front & 14mm rear.
given you have thicker front & rear swaybars on a lowered car & an endlink has broken, it would be worth checking if there's preload from the angle of the swaybar arm ends in relation to the ground (i.e. see CT's post above). but given Josh reckons 30-50mm lower is not a problem, i wouldn't have thought 2mm thicker swaybars front & rear would break endlinks. may be you're over 50mm lower &/ or have really thick swaybars, in which case adjustable endlinks might be the way to go. or may be an endlink got damaged from road debris?
mhj
Postby mhj » Sun Aug 23, 2009 9:57 pm
thanks 93...i'll ask mania when next i'm there
enjoy
mhj
Wholesale Suspension
Postby Wholesale Suspension » Mon Aug 24, 2009 3:43 pm
If you got them from Maina and they are a Signiture bar, they will be either 22mm or 24mm front.
rear will be 16mm unless otherwise specified.
I would look into that, we have done countless MX5's over the last 20 years, big sways and lowered and not really had dramas with the links, maybe check that they were not over tightened or put on at the wrong angle?
Cheers Josh
129 Coreen Ave
Penrith
pat@wholesalesuspension.com.au
02 4721 2112
Users browsing this forum: No registered users and 153 guests
