One side higher than the other.
Postby sliq » Sun May 31, 2009 6:24 pm
Szemen wrote:But it sounds VERY normal :?
why the disgruntled face?
it gives our cars character!
you can have 20 mx5's in a garage.
all have same rims, or front lips, clear indicators, etc.
the thing that will separate them all are its squeaks and squeals and funny, uneven heights :lol:
StanTheMan
Postby StanTheMan » Sun May 31, 2009 7:54 pm
it isn't normal
philz
Wheel guru
Postby philz » Sun May 31, 2009 8:13 pm
I just checked my height again today, it's all the same for both sides (for stock oem coils).
Did they preload the suspension when tightening, or was it just on a hoist.
Szemen
Postby Szemen » Sun May 31, 2009 9:35 pm
Didn't preload it no. How can you preload it and then tighten when the car is so low?
StanTheMan
Postby StanTheMan » Sun May 31, 2009 9:44 pm
get someone who has a ramp hoist to do it for you.
Szemen
Postby Szemen » Sun May 31, 2009 9:56 pm
I see, I take it just ddrive up onto the hoist. Loosen all bolts on the LCA and torque them back up again?
StanTheMan
Postby StanTheMan » Mon Jun 01, 2009 10:45 am
something like that......probably need move the car frontward & backward & wiggle it a little bit as well so it all settles nicely. If that doesn't work..........not really sure then.
wun911
Postby wun911 » Mon Jun 01, 2009 2:29 pm
When I corner weight the car I had a similar expereince. All my coilover spring perch heights were different side to side; both front and back. They are all set at slighly different, but when I get into the car it all evens out.
every ounce counts
Postby manga_blue » Tue Jun 02, 2009 12:27 am
When I was levelling my car I tried swapping the springs across at each end. It made no difference. The springs had not settled, it was in the chassis somewhere.
Szemen
Postby Szemen » Tue Jun 02, 2009 5:58 pm
Passenger side
By szemen, shot with Canon DIGITAL IXUS 700 at 2009-06-01
Driver side
I think its more than sag. I would say the old OEM dampers would be sagging due to the weight, but not these...As manga_blue hypothesized, its prob in the chassis.
Ando
Postby Ando » Tue Jun 02, 2009 6:36 pm
I think Mazda preset the odd passenger side height to mirror the future driver's testicles, so any body roll can be cancelled out? Are your plums out of plumb?? :mrgreen:
Ando
~ 1999 Twilight Blue NB8A ~
1として馬そしてライダー
Szemen
Postby Szemen » Wed Jun 03, 2009 10:57 am
My right side is about the size of a grapefruit...I though this was normal..... :oops:
