I'm happy.
- Steampunk
- TieNN89
I'm happy.
saboteur wrote:They stick like sh*t to a blanket!!
mmm you know this because??
sounds like you know from experience
- Vehicle: Non MX-5
I'm happy.
wet grip good. 1st 3 weeks using them was full of qld storms and floods.
used about 0.3mm for 1300km for street driving with weekly spirited mountain runs.. so i'll get 20-25,000km out of them.
- TieNN89
I'm happy.
My set are on
At first driving it out of the tyre shop
Steering was just shocking light
And tyres weren't gripping as good as I thought
but after a few ks the coating i assume started to wear off and its sticky
I Like
I Like
- TieNN89
I'm happy.
What PSI are you guys running?
The tyre shop put 36 front and 34 rear
i pumped them up to 38
- AJ
I'm happy.
38 psi is track pressure Tien, ok on nice smooth bitumen, but they'll probably shake your back teeth out on suburban roads, I'd advise 34 - 36 all 'round for street.........don't run different pressures f & r, in a well balanced car like the MX-5, it'll only upset things
XMX5 Rogues
- Vehicle: Non MX-5
I'm happy.
i run 36psi all round.
- Steampunk
I'm happy.
YEEEE-HA!
These tyres are AWESOME on the track.
zero squealing, plenty of bite.
Very communicative when the rear-end lets go, and all you do to adjust your line is simply push and release the loud-pedal
The outside shoulder-block showed minimal sign of wear at 38psi cold/42psi hot.
I managed to cut more than 2 seconds off my time without seeming to try much harder than usual.
I will definitely get these again.
Oh.... one thing about these tyres though.... they are HEAVY!
Hopefully this means high-quality rubber and strong innards.
- Vehicle: Non MX-5
I'm happy.
heavy? i found them light. at least compare to other street tyres.
