Wheel nuts
Wheel nuts
Stock = 32.5774 g
Some nice volk nuts for sale the guy says they are 0.8 oz thats only 22.6796185 grams. Apparently they are the 'long ones' so if you angle grind them down they have potential to be less than 20 grams per nut.
So saving 40 grams per wheel, all rotational unsprung weight savings it simply can't be compared to static weight savings.
every ounce counts
- HIC-45S
Wheel nuts
wun911 wrote:so if you angle grind them down they have potential to be less than 20 grams per nut.
One could also purchase the short type so you don't need to grind them down
Nengun says RAYs wheel nuts are around 23g. If I had the equipment I'd weigh up one of mine and confirm
However, not cheap. Nengun again says $204.51 per pack of 20 delivered to Sydney. This is assuming that they are compatible with the rims, rather expensive exercise if they aren't.
スカイライン ECR33 GTS25-t SII
"We produced with Spartan air"
Wheel nuts
Whats the grade of the aluminum they use for the rays nuts? Im looking for a 4 digit number hopefully starting with the number 7.
every ounce counts
- philz
- Wheel guru
Wheel nuts
Depends which one...
The normal rays one is made of duraluminium
Volk Racing Formula are Aluminium 7075
- Szemen
Wheel nuts
Lug nuts confuse me Some have a huge tip. Normal lug nuts aren't like that...How are those suppose to fit?
- Locutus
Wheel nuts
aftermarket lug nuts are designed to fit aftermarket wheels. generally, you can't use a aftermarket lug nuts with stock wheels or stock lug nuts with aftermarket wheels.
- philz
- Wheel guru
Wheel nuts
Well it varies.
It depends if the seat face is Tapered or spherical.
Aftermarket are generally Tapered, and wheels are designed for tapered.
Honda uses Spherical, and as colour lug nuts are Honda modifiers common mod, it is frowned when they use stock wheels with aftermarket lugs.
However mazdas/mx5s are tapered, which are the same as aftermarket so it's okay to use.
- philz
- Wheel guru
Wheel nuts
Yep Mx-5s are M12-P1.5mm
Same as thread as Honda.
Wheel nuts
every ounce counts
- AB7
Wheel nuts
What brand of nuts you got there Wun?
I must say Volks nuts is way overpriced...plenty of cheaper taiwan/ china brand that is also as light and as good.
Personally I got McGard, not as light but the key is very rare and specific to McGard...so hopefully will be safer.
- philz
- Wheel guru
Wheel nuts
True, you can get cheaper.
Shift performance sell these for $100.
But in saying that, The normal short nut rays are duraluminium grade 2***
The Racing formula ones are grade a7075 on the tapered head only.
Wheel nuts
I dont know because the writing is in chinese...
I dont understand duraluminium grade 2*** that means the grade of aluminum is very low like not as strong??
every ounce counts
- philz
- Wheel guru
Wheel nuts
It's in Japanese, not that I know what it saying, the pic is for reference of the different ray nuts.
One is Duraluminium, the other is Chrome Vanadium + aluminum (a7075).
Duraluminium (mixture of copper and magnesium etc) is much more softer compared to normal aluminum, but it keeps the weight down to 22g each.
7075 is the highest strength in aluminium alloys.
Wheel nuts
Sorry confused people. AB7 asked what my nuts were and I dont know because the writing on them is in chinese.
I know a friend of mine got these nuts for only $85 dollars they are also 7075.
http://firesport.com.au/d1-spec-light-w ... 131971.htm
A bit of the paint comes off as you tighten them, but I would rather have the nut tight than wheel falls off.
I might weigh one of them one day if anyone is intereted (would be deeply cut if its lighter than mine)
I kinda like these ones
http://www.nahux.com/NPOWER/manufacturer.php?mid=16
I think its cheaper because you only get 16 nuts instead of 20 nuts.
every ounce counts
Users browsing this forum: No registered users and 228 guests
