Willwood brakes vs Standard Calipers
Fuzzlet
Postby Fuzzlet » Sun Nov 23, 2008 12:03 am
Okibi wrote:As Liam has shown, if the NB8B brakes don't have good pads, are well bled, well maintained etc. the difference is chalk and cheese.
I assume the Wilwood set-up at its worst (within reason) should be at least as good as the stock brakes at their best.
This is what I was thinking...especially since its not even half an inch in disc diameter
Caffeine
Postby Caffeine » Sun Nov 23, 2008 10:35 am
Indeed, I fixed the slider pin seizing issue, fitted some hawk HP+ pads, and a good bleed. Now the car manages peaks of 1.3G under brakes, with averages around the 1G mark...
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Wed Nov 26, 2008 9:46 am
The SE brakes are actually very good...as Chris said we run the stock brake set up with Hawk Blues...even on treaded tyres we can outbrake most of the cars on the track...same with the green car...I just have the stock NA8 brakes on it...with hawk Blues...
I would not run Hawk Blues on a road car...they are way too aggressive...I would run some of the Hawk HP or one of those...but they are pretty dusty.
Fuzzlet
Postby Fuzzlet » Wed Nov 26, 2008 10:27 am
Boyracer wrote:I would not run Hawk Blues on a road car...they are way too aggressive...I would run some of the Hawk HP or one of those...but they are pretty dusty.
Yea I'll just run HP+...will cost less in the long run. I think its just whatever pads are in the SE at the moment are pretty well stuffed. Previous owner said he'd done a couple of track days in it, and I'm pretty sure on those pads, so he might of put a glaze on them...
Charlie Brown
Postby Charlie Brown » Wed Nov 26, 2008 10:45 am
Fuzzlet wrote:Yea I'll just run HP+...will cost less in the long run. I think its just whatever pads are in the SE at the moment are pretty well stuffed. Previous owner said he'd done a couple of track days in it, and I'm pretty sure on those pads, so he might of put a glaze on them...
Hmm, I don't know.
Previous owner only turned in times in the vicinity of 1:16s around Wakefield on the few occasions he was there, so the SE wasn't really stretched.
Throw a set of pads into her, send off a Club membership application and entry to Wakefield for Sunday week (7th) and come and give it a go.
There's only 3 places that you need to brake, so you might even get away with the current pads. From memory you should be able to beat your old time pretty easily. :D
Caffeine
Postby Caffeine » Wed Nov 26, 2008 11:05 am
Charlie Brown wrote:Previous owner only turned in times in the vicinity of 1:16s around Wakefield on the few occasions he was there, so the SE wasn't really stretched.
Perhaps he was braking too much?
I remember when Chris Tonna, Biggles and I started track days. After 25000km and similar number of track days, Chris and I had ~6mm pad left on the front of our cars, Biggles had less than 1mm! Different braking / driving styles use different amount of pad...
Fuzzlet
Postby Fuzzlet » Wed Nov 26, 2008 4:16 pm
Charlie Brown wrote:Hmm, I don't know.
Club membership is in the mail, however I'm going to be in Forster for that track day :(
As for beating my old times - that wont be hard. Its amazing what a set of shagged tyres combined with lack of confidence can do haha
Fuzzlet
Postby Fuzzlet » Wed Dec 03, 2008 6:59 pm
Well I have new pads and discs on order (Hawk HP+ and DBA slotted rotors), and just replaced the brake fluid. My gods what a difference just basically bleeding the brakes can give!
Users browsing this forum: No registered users and 72 guests
